주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iRobot Roomba 560 Fan Replacement
필요한 것
    1. iRobot Roomba 560 Fan Replacement, Fan: 1 단계, 이미지 1개 중 1개
      • Press the black circular button on the back end of the Roomba and pull the bin out towards you to remove the vacuum bin.
      댓글 쓰기
    2. iRobot Roomba 560 Fan Replacement: 2 단계, 이미지 2개 중 1개 iRobot Roomba 560 Fan Replacement: 2 단계, 이미지 2개 중 2개
      • Lay the vacuum bin down and remove the six 15 mm screws around the outside of the vacuum bin using the Phillips JIS #1 driver.
      • Remove the top of the vacuum bin by pulling it straight up.
      • The bin is composed of two parts (the clear top casing and the red bottom filter). To avoid a mess, be careful to not let these two pieces detach, unless over a trash bin.
      댓글 쓰기
    3. iRobot Roomba 560 Fan Replacement: 3 단계, 이미지 3개 중 1개 iRobot Roomba 560 Fan Replacement: 3 단계, 이미지 3개 중 2개 iRobot Roomba 560 Fan Replacement: 3 단계, 이미지 3개 중 3개
      • Remove the three 10 mm screws that surround the fan using the Phillips JIS #1 driver.
      • Remove the casing that surrounds the fan by pulling it straight up.
      • The casing is composed of 2 parts (the large top casing, and a small air filter). If these parts detach, they are very easy to put back together. Do not lose the air filter.
      댓글 쓰기
    4. iRobot Roomba 560 Fan Replacement: 4 단계, 이미지 3개 중 1개 iRobot Roomba 560 Fan Replacement: 4 단계, 이미지 3개 중 2개 iRobot Roomba 560 Fan Replacement: 4 단계, 이미지 3개 중 3개
      • Turn over the remainder of the fan casing and remove the single 15mm screw, using the Phillips JIS #1 screwdriver.
      • Remove the casing from the fan and battery component by pulling it straight up.
      댓글 쓰기
    5. iRobot Roomba 560 Fan Replacement: 5 단계, 이미지 1개 중 1개
      • Remove the small black button from the top of the battery.
      • Save the spring and the button cover. The remainder of the fan assembly (yellow motor and the black housing) will need to be replaced as a unit.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
TJ Tamura
회원 가입일: 10/01/15
289 평판
안내서 1개를 작성함
Cal Poly, Team 1-22, Maness Fall 2015 Cal Poly, Team 1-22, Maness Fall 2015 회원
CPSU-MANESS-F15S1G22
4 회원들
안내서 21개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 14
지난 30일: 49
전체 시간: 5,271
