주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iRobot Roomba 650 Battery Replacement
필요한 것
동영상 개요
    1. iRobot Roomba 650 Battery Replacement, Removing the Side Brush: 1 단계, 이미지 2개 중 1개 iRobot Roomba 650 Battery Replacement, Removing the Side Brush: 1 단계, 이미지 2개 중 2개
      • With the Roomba upside down and turned off, use the Phillip's 02 screwdriver to remove the one 3.5 mm screw from the center of the side-brush.
      • Set the screw aside and pull the brush out.
      댓글 쓰기
    2. iRobot Roomba 650 Battery Replacement, Bottom Panel Removal: 2 단계, 이미지 2개 중 1개 iRobot Roomba 650 Battery Replacement, Bottom Panel Removal: 2 단계, 이미지 2개 중 2개
      • Unscrew the four screws that hold the bottom panel using the Phillips 02 screwdriver.
      • The screws will not come out of the bottom panel. They were designed to become loose but not be removed. This prevents you from losing them, and prevents the Roomba from sucking them up if they came out during cleaning.
      • Once you are sure that all the screws have been loosened as much as possible, then lift the bottom panel up off the Roomba.
      댓글 쓰기
    1. iRobot Roomba 650 Battery Replacement, Battery: 3 단계, 이미지 1개 중 1개
      • Once the side brush and bottom panel are out of the way, simply grasp the battery by the two green flaps and pull it out.
      • In the unlikely event that the battery has leaked acid, avoid all contact with it and any surfaces it has affected. Wear protective gloves and wipe up any residue with a paper towel. Secure the battery in a plastic bag and dispose of it properly.
      • If you get battery acid on your skin or in your eye, flush immediately with water and seek medical attention.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 17명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Charles Ward
회원 가입일: 01/22/15
1,026 평판
안내서 3개를 작성함
Cal Poly, Team 19-7, Maness Winter 2015 Cal Poly, Team 19-7, Maness Winter 2015 회원
CPSU-MANESS-W15S19G7
4 회원들
안내서 12개를 작성함
1가이드 댓글
We thought we were going to have to put Boohya down (our toddler named it that) so he is very happy that by simply replacing the battery we brought him back to life! Thanks! $17 well spent.
Deedra Wollert - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 16
지난 30일: 61
전체 시간: 19,345
