주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iRobot Roomba 650 Main Wheel Replacement
필요한 것
    1. iRobot Roomba 650 Main Wheel Replacement, Removing the Side Brush: 1 단계, 이미지 2개 중 1개 iRobot Roomba 650 Main Wheel Replacement, Removing the Side Brush: 1 단계, 이미지 2개 중 2개
      • With the Roomba upside down and turned off, use the Phillip's 02 screwdriver to remove the one 3.5 mm screw from the center of the side-brush.
      • Set the screw aside and pull the brush out.
      댓글 쓰기
    2. iRobot Roomba 650 Main Wheel Replacement, Bottom Panel Removal: 2 단계, 이미지 2개 중 1개 iRobot Roomba 650 Main Wheel Replacement, Bottom Panel Removal: 2 단계, 이미지 2개 중 2개
      • Unscrew the four screws that hold the bottom panel using the Phillips 02 screwdriver.
      • The screws will not come out of the bottom panel. They were designed to become loose but not be removed. This prevents you from losing them, and prevents the Roomba from sucking them up if they came out during cleaning.
      • Once you are sure that all the screws have been loosened as much as possible, then lift the bottom panel up off the Roomba.
      댓글 쓰기
    1. iRobot Roomba 650 Main Wheel Replacement, Main Wheels: 3 단계, 이미지 2개 중 1개 iRobot Roomba 650 Main Wheel Replacement, Main Wheels: 3 단계, 이미지 2개 중 2개
      • Unscrew the six 12mm screws holding the side wheels on using a Phillips 00 screwdriver. There should be 3 on each side.
      • The screws do not come all the way out.
      • Remove the wheels by pulling them out.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Alex Schnorr
회원 가입일: 01/22/15
649 평판
안내서 3개를 작성함
Cal Poly, Team 19-7, Maness Winter 2015 Cal Poly, Team 19-7, Maness Winter 2015 회원
CPSU-MANESS-W15S19G7
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 29
전체 시간: 4,932
