주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iRobot Roomba i7 Filter Replacement
필요한 것
    1. iRobot Roomba i7 Filter Replacement, Filter: 1 단계, 이미지 1개 중 1개
      • Flip the iRobot Roomba i7 so that the underside is facing upwards and the back is facing you.
      • On the left side at the back press the release button for the waste bin.
      댓글 쓰기
    2. iRobot Roomba i7 Filter Replacement: 2 단계, 이미지 1개 중 1개
      • Once the bin is removed, empty any waste into a trash can.
      • Be careful while emptying. Dust may escape and cause allergies.
      댓글 쓰기
    3. iRobot Roomba i7 Filter Replacement: 3 단계, 이미지 1개 중 1개
      • Locate the filter on the side of the bin.
      • Placing your fingers on the light grey area, pull the filter directly out of the bin.
      • If replacing the filter, follow these steps in reverse order.
      댓글 쓰기
    4. iRobot Roomba i7 Filter Replacement: 4 단계, 이미지 1개 중 1개
      • To clean the filter, tap it on the inside of a trash can.
      • Be careful not to shake dust everywhere; it may cause allergies.
      • Do not clean the filter with any type of liquid.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
3가이드 댓글
Question, please! I am unable to pull the filter out of the bin. It’s stuck. Any suggestions?
Christopher Liddle - 답글 공유
This little filter barely does it's job. even after installing a brand new one, it'll be huffing and puffing dust everywhere it goes. My old Eufy 35C did a much better job than this much more expensive Roomba.
w.vries - 답글 공유
I replaced the filter but it’s still not working.
Ashley Marie Vazquez - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 11
지난 7일: 56
지난 30일: 197
전체 시간: 14,289
