주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iVIEW-754TPC Battery Replacement
필요한 것
    1. iVIEW-754TPC Battery Replacement, Rear Panel: 1 단계, 이미지 3개 중 1개 iVIEW-754TPC Battery Replacement, Rear Panel: 1 단계, 이미지 3개 중 2개 iVIEW-754TPC Battery Replacement, Rear Panel: 1 단계, 이미지 3개 중 3개
      • Before disassembling your tablet, make sure it is powered off.
      • Use plastic opening tool to release the clips holding the device together. The clips will take a small amount of pressure to release. Once you have the plastic opening tool inserted, use a twisting action to release the clips. Start from bottom of device and work all the way around.
      댓글 쓰기
    1. iVIEW-754TPC Battery Replacement, Remove Battery: 2 단계, 이미지 3개 중 1개 iVIEW-754TPC Battery Replacement, Remove Battery: 2 단계, 이미지 3개 중 2개 iVIEW-754TPC Battery Replacement, Remove Battery: 2 단계, 이미지 3개 중 3개
      • Use flat side of the spudger to get under battery and use pressure to release from glue. Do this all the way around battery until it comes off.
      • At this point do not attempt to fully remove the battery as it is still attached to the logic board.
      댓글 쓰기
    1. iVIEW-754TPC Battery Replacement, Desolder wires: 3 단계, 이미지 3개 중 1개 iVIEW-754TPC Battery Replacement, Desolder wires: 3 단계, 이미지 3개 중 2개 iVIEW-754TPC Battery Replacement, Desolder wires: 3 단계, 이미지 3개 중 3개
      • Once battery is off, the wires will still be connected to motherboard. You will need to desolder the wires.
      • Using the soldering tool, use the heat to melt the connection. As you do this, pull on the wires with a tweezer until wires comes off.
      • To ease reassembly, take note of which wire goes to the negative and positive terminals.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
calvin
회원 가입일: 01/21/15
188 평판
안내서 1개를 작성함
USF Tampa, Team 5-4, Brown Winter 2015 USF Tampa, Team 5-4, Brown Winter 2015 회원
USFT-BROWN-W15S5G4
4 회원들
안내서 48개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 39
전체 시간: 2,823
