주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ionvac SmartClean V2 Motor Wheel Replacement
필요한 것
  1. ionvac SmartClean V2 Motor Wheel Replacement, Shell (Top & Bottom): 1 단계, 이미지 2개 중 1개 ionvac SmartClean V2 Motor Wheel Replacement, Shell (Top & Bottom): 1 단계, 이미지 2개 중 2개
    • Caution: Before beginning, turn off the ionvac and place it on a level surface.
    • Keep in mind that your ionvac has many small screws that can be easily lost. Using a magnetic project mat is best to prevent misplacing any parts.
    • Flip your ionvac right-side up, turning it so that the front filter vents are facing forward and the power button is furthest from you.
    댓글 쓰기
  2. ionvac SmartClean V2 Motor Wheel Replacement: 2 단계, 이미지 3개 중 1개 ionvac SmartClean V2 Motor Wheel Replacement: 2 단계, 이미지 3개 중 2개 ionvac SmartClean V2 Motor Wheel Replacement: 2 단계, 이미지 3개 중 3개
    • Use a Phillips screwdriver to remove the 8 screws indicated in red holding the base together.
    • Use the same screwdriver to remove the 8 screws indicated in orange which hold the rims (bumper arms).
    • Remove the rims from your ionvac and set them aside.
    댓글 쓰기
  3. ionvac SmartClean V2 Motor Wheel Replacement: 3 단계, 이미지 1개 중 1개
    • Flip your ionvac right-side up and tilt it upwards at a 45 degree angle.
    • Use a Jimmy or prying tool to wedge the sharp end through the bottom crevice (below the sensors).
    • Continue prying the outside rim of your ionvac open. You will feel the top shell (frame or cover) loosen.
    • Caution: Resist the urge to tear the top shell open until the entire rim has been loosened.
    댓글 쓰기
  4. ionvac SmartClean V2 Motor Wheel Replacement: 4 단계, 이미지 2개 중 1개 ionvac SmartClean V2 Motor Wheel Replacement: 4 단계, 이미지 2개 중 2개
    • Lift the top shell off carefully.
    댓글 쓰기
  5. ionvac SmartClean V2 Motor Wheel Replacement, Motor Wheel: 5 단계, 이미지 1개 중 1개
    • Remove the 3 screws securing the cable assembly housing on the outer side of the motor wheel frame labeled either R (right wheel) or L (left wheel).
    • Set the cable assembly housing to the side.
    댓글 쓰기
  6. ionvac SmartClean V2 Motor Wheel Replacement: 6 단계, 이미지 2개 중 1개 ionvac SmartClean V2 Motor Wheel Replacement: 6 단계, 이미지 2개 중 2개
    • Unscrew the 3 screws securing the motor wheel frame.
    • Dislodge the wheel motor frame from the bottom shelf.
    댓글 쓰기
  7. ionvac SmartClean V2 Motor Wheel Replacement: 7 단계, 이미지 1개 중 1개
    • Disconnect the cable attaching the motor wheel frame to the logic board.
    댓글 쓰기
  8. ionvac SmartClean V2 Motor Wheel Replacement: 8 단계, 이미지 2개 중 1개 ionvac SmartClean V2 Motor Wheel Replacement: 8 단계, 이미지 2개 중 2개
    • Carefully pull one end of the spring out of place to remove it from the motor wheel frame.
    • This will separate the motor wheel frame from the motor wheel assembly.
    댓글 쓰기
  9. ionvac SmartClean V2 Motor Wheel Replacement: 9 단계, 이미지 1개 중 1개
    • Unscrew the five screws from the motor wheel assembly.
    댓글 쓰기
  10. ionvac SmartClean V2 Motor Wheel Replacement: 10 단계, 이미지 2개 중 1개 ionvac SmartClean V2 Motor Wheel Replacement: 10 단계, 이미지 2개 중 2개
    • Gently lift the clip on the side to separate the casing and expose the white plastic gears.
    댓글 쓰기
  11. ionvac SmartClean V2 Motor Wheel Replacement: 11 단계, 이미지 1개 중 1개
    • Remove all but the largest gear to expose the silver screws and washers underneath.
    • Unscrew and remove the two silver screws along with each accompanying set of two washers.
    • Now you can remove the motor from the wheel assembly.
    • To clean the motor, use a soft cloth or alcohol wipe.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Andre
회원 가입일: 09/13/23
175 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 47
전체 시간: 1,045
