주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ionvac SmartClean V2 Power Button Replacement
필요한 것
  1. ionvac SmartClean V2 Power Button Replacement, Shell (Top & Bottom): 1 단계, 이미지 2개 중 1개 ionvac SmartClean V2 Power Button Replacement, Shell (Top & Bottom): 1 단계, 이미지 2개 중 2개
    • Caution: Before beginning, turn off the ionvac and place it on a level surface.
    • Keep in mind that your ionvac has many small screws that can be easily lost. Using a magnetic project mat is best to prevent misplacing any parts.
    • Flip your ionvac right-side up, turning it so that the front filter vents are facing forward and the power button is furthest from you.
    댓글 쓰기
  2. ionvac SmartClean V2 Power Button Replacement: 2 단계, 이미지 3개 중 1개 ionvac SmartClean V2 Power Button Replacement: 2 단계, 이미지 3개 중 2개 ionvac SmartClean V2 Power Button Replacement: 2 단계, 이미지 3개 중 3개
    • Use a Phillips screwdriver to remove the 8 screws indicated in red holding the base together.
    • Use the same screwdriver to remove the 8 screws indicated in orange which hold the rims (bumper arms).
    • Remove the rims from your ionvac and set them aside.
    댓글 쓰기
  3. ionvac SmartClean V2 Power Button Replacement: 3 단계, 이미지 1개 중 1개
    • Flip your ionvac right-side up and tilt it upwards at a 45 degree angle.
    • Use a Jimmy or prying tool to wedge the sharp end through the bottom crevice (below the sensors).
    • Continue prying the outside rim of your ionvac open. You will feel the top shell (frame or cover) loosen.
    • Caution: Resist the urge to tear the top shell open until the entire rim has been loosened.
    댓글 쓰기
  4. ionvac SmartClean V2 Power Button Replacement: 4 단계, 이미지 2개 중 1개 ionvac SmartClean V2 Power Button Replacement: 4 단계, 이미지 2개 중 2개
    • Lift the top shell off carefully.
    댓글 쓰기
  5. ionvac SmartClean V2 Power Button Replacement, Power Button: 5 단계, 이미지 1개 중 1개
    • Flip the frame upside down so that the inside faces upwards.
    • Locate the 2 screws connecting the power button to the frame.
    댓글 쓰기
  6. ionvac SmartClean V2 Power Button Replacement: 6 단계, 이미지 1개 중 1개
    • Unscrew the two screws connecting the power button to the top shell.
    댓글 쓰기
  7. ionvac SmartClean V2 Power Button Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the power button from the shell.
    • Position the power button correctly when reinstalling. The power icon should face the ionvac logo and the house icon should face the front of the robot vacuum.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Ruth Mekonnen
회원 가입일: 09/11/23
794 평판
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 19
전체 시간: 711
