주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ionvac SmartClean V2 Shell (Top & Bottom) Replacement
필요한 것
    1. ionvac SmartClean V2 Shell (Top & Bottom) Replacement, Shell (Top & Bottom): 1 단계, 이미지 2개 중 1개 ionvac SmartClean V2 Shell (Top & Bottom) Replacement, Shell (Top & Bottom): 1 단계, 이미지 2개 중 2개
      • Caution: Before beginning, turn off the ionvac and place it on a level surface.
      • Keep in mind that your ionvac has many small screws that can be easily lost. Using a magnetic project mat is best to prevent misplacing any parts.
      • Flip your ionvac right-side up, turning it so that the front filter vents are facing forward and the power button is furthest from you.
      댓글 쓰기
    2. ionvac SmartClean V2 Shell (Top & Bottom) Replacement: 2 단계, 이미지 3개 중 1개 ionvac SmartClean V2 Shell (Top & Bottom) Replacement: 2 단계, 이미지 3개 중 2개 ionvac SmartClean V2 Shell (Top & Bottom) Replacement: 2 단계, 이미지 3개 중 3개
      • Use a Phillips screwdriver to remove the 8 screws indicated in red holding the base together.
      • Use the same screwdriver to remove the 8 screws indicated in orange which hold the rims (bumper arms).
      • Remove the rims from your ionvac and set them aside.
      댓글 쓰기
    3. ionvac SmartClean V2 Shell (Top & Bottom) Replacement: 3 단계, 이미지 1개 중 1개
      • Flip your ionvac right-side up and tilt it upwards at a 45 degree angle.
      • Use a Jimmy or prying tool to wedge the sharp end through the bottom crevice (below the sensors).
      • Continue prying the outside rim of your ionvac open. You will feel the top shell (frame or cover) loosen.
      • Caution: Resist the urge to tear the top shell open until the entire rim has been loosened.
      댓글 쓰기
    4. ionvac SmartClean V2 Shell (Top & Bottom) Replacement: 4 단계, 이미지 2개 중 1개 ionvac SmartClean V2 Shell (Top & Bottom) Replacement: 4 단계, 이미지 2개 중 2개
      • Lift the top shell off carefully.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Ruth Mekonnen
회원 가입일: 09/11/23
794 평판
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 23
전체 시간: 392
