주요 콘텐츠로 건너뛰기
iPhone 6s 배터리 교체
5 단계 번역중
5 단계
iPhone 6s Battery Replacement, Battery Removal: 0 단계, 이미지 1개 중 1개
Battery Removal
  • Remove the battery.
  • If your replacement battery came in a plastic sleeve, remove the sleeve before installation by pulling it away from the ribbon cable.
  • If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
  • Before you adhere the replacement battery, temporarily reconnect the battery connector to the logic board socket. This ensures that the battery is properly aligned in its recess.
  • Adhere the battery, disconnect it, and continue reassembling your device.
  • If your new battery doesn’t have adhesive preinstalled, refer to this guide to replace the adhesive strips.
  • Perform a forced restart after reassembly. This can prevent several issues and simplify troubleshooting.
배터리를 분리하세요.
교체 배터리가 플라스틱 슬리브에 들어있는 경우 설치하기 전에 리본 케이블 반대편으로 배터리를 당겨 슬리브에서 꺼내세요.
새 배터리에 접착제가 사전 설치되어 있지 않은 경우, 이 안내서를 참조하여 접착제 스트립을 교체하세요.
재조립한 다음 휴대폰을 다시 시작하세요. 다시 시작하면 여러가지 문제를 방지하며 문제 해결을 간소화합니다.
+[title] Battery Removal
[* black] Remove the battery.
[* icon_note] If your replacement battery came in a plastic sleeve, remove the sleeve before installation by pulling it away from the ribbon cable.
+[* icon_reminder] If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
+[* icon_reminder] Before you adhere the replacement battery, temporarily reconnect the battery connector to the logic board socket. This ensures that the battery is properly aligned in its recess.
+ [* black] Adhere the battery, disconnect it, and continue reassembling your device.
[* icon_reminder] If your new battery doesn’t have adhesive preinstalled, refer to [guide|56465|this guide] to replace the adhesive strips.
[* icon_reminder] Perform a [guide|62334|forced restart] after reassembly. This can prevent several issues and simplify troubleshooting.
귀하의 기여는 오픈 소스 Createive Commons 라이선스 하에 허가되었습니다.
