PC2-5300 4 GB RAM Chip
  • PC2-5300 4 GB RAM Chip
US$74.99
US$74.99
제품 재입고 메시지를 보내드리겠습니다.
US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
제품 정보
설명
설명
Adding RAM to your computer can provide a significant performance boost.
Works only in Macbooks and MacBook Pros with Santa Rosa or Penryn chip sets. This chip will not work in computers with Core Duo or Core 2 Duo (non-Santa Rosa or Penryn) processors. If you're not sure which model computer you have, identify your Mac. The Santa Rosa and Penryn Core 2 Duo MacBooks and MacBook Pros can address up to 6 GB of RAM using this chip along with a 2 GB RAM chip.
You may receive a PC2-6400 RAM chip instead. These chips are fully backwards compatible and will function identically to the PC2-5300 chips.
호환성
iMac Intel 17"
2 GHz
2.16 GHz
iMac Intel 20" EMC 2105 and 2118
2.16 GHz
2.33 GHz
iMac Intel 20" EMC 2133 and 2210
2 GHz (EMC No. 2133)
2.4 GHz (EMC No. 2133)
iMac Intel 24" EMC 2111
2.16 GHz
2.33 GHz
iMac Intel 24" EMC 2134 and 2211
2.4 GHz (EMC No. 2134)
2.8 GHz (EMC No. 2134)
Mac Mini Model A1176
1.83 GHz (Core 2 Duo, Mid 2007)
2 GHz (Core 2 Duo)
MacBook Core 2 Duo
1.83 GHz
2 GHz (Early 2009)
2 GHz (Late 2006)
2 GHz (Mid 2007)
2 GHz (Santa Rosa)
2.1 GHz (Penryn)
2.13 GHz (Mid 2009)
2.16 GHz
2.2 GHz (Santa Rosa)
2.4 GHz (Penryn)
MacBook Pro 15" Core 2 Duo Models A1226 and A1260
2.4 GHz (Penryn)
2.4 GHz (Santa Rosa)
2.5 GHz (Penryn)
2.6 GHz (Penryn)
2.6 GHz (Santa Rosa)
MacBook Pro 17" Models A1151 A1212 A1229 and A1261
2.5 GHz (Penryn)
2.6 GHz (Penryn)
기기 6개 더 보기
수리 경험담
사용자 아바타
내 문제
I am trying to avoid spending a bunch of money on a Mac Pro. My MBP came with 4 GB ram, 10 years ago. I recently heard somewhere it was possible to increase it to 6 MB. I talked with a tech at ifixit.com and found out it was in fact possible. Ordered the part on line (about $95 with shipping).
나의 수리
The pa . . .
사용자 아바타
내 문제
I wanted to see if the rumors were true that I could run 6gb of ram in my iMac 7,1
나의 수리
It was very easy just popped the ram door, put the ram in and booted up to make sure the ram was being recognized and used before reinstalling the ram door
내 조언
6gb of ram works in an iMac 7,1. Be gentile if it's your first . . .
사용자 아바타
내 문제
I wanted to upgrade my Apple iMac from 2 to 8 GB to speed it up because I was experiencing a lot of swapping.
나의 수리
I ordered 2x PC2-5300 4 GB RAM chips on iFixit to replace the 2x 1 GB in my iMac.
At first it did not work, the iMac would not boot, and Ryan from iFixit advised that my computer could not ta . . .
사용자 아바타
내 문제
My Macbook Pro was running real slow, so I upgraded from 2GB to 5GB.
나의 수리
It went real smooth. I just needed to take off the battery, three screws, pop off the old ram and insert the new one.
내 조언
No, even a girl can do it ;)!
사용자 아바타
내 문제
I had to upgrade the RAM in my 2007 Mac Book Pro 15" in order to install and run IOS Maverick smoothly. I was running on 2 gigs of ram and based on some web research I did, I had to upgrade my RAM to at least 4 gigs. I went to the Apple store to see if they provided this service and how much they we . . .
사용자 아바타
내 문제
Well my MacBook Pro was getting slower and slower through the years and i was upset by this so i finally decided to boost the RAM. Exit the basic 2go and welcome the 6go!
나의 수리
Really simple and easy. That's it. My MBP is much more quicker and i enjoy use it again.
내 조언
Here is a second life for my MBP and may . . .
사용자 아바타
내 문제
The original 1 GB was just not cutting it on this old puppy... Also, OS 10.6.8 is as far as it would upgrade, leaving me out of the Cloud.
나의 수리
Everything went super smooth and easy!
I wish I had thought of doing it myself earlier!
Though the upgrade to I OS 10.7 is still on hold due to something str . . .
사용자 아바타
내 문제
Upgrade vs. new
나의 수리
Piece of cake...very straight forward. Formatting hard drive and setting up OS X was the only process that took some time
내 조언
Keep it up! Thanks
사용자 아바타
내 문제
I had ruined the keyboard by trying to clean it with a dampened cloth and Windex. I found out later to use only distilled water, and a minimum of that on a cloth, wrung-out as much as possible.
Since I had to go in to replace the keyboard [from Amazon], I also decided to max out the RAM to 6GB, . . .
사용자 아바타
내 문제
Slow performance in my MacBook 13'' Early 2009. Run out of disk space.
나의 수리
Smooth. Simple. Upgrading memory and Hard Drive are among the easiest task you can do in this MacBook model.
내 조언
Before taking out the Hard Drive, I repaired permissions. I used the rubber case included in the kit to be able to use the . . .
더 보기
