주요 콘텐츠로 건너뛰기
« 모든 스토리로 돌아가기
3GS Mute Button
g15389 -
iPhone 3G
스토리 이미지
  • 이미지 #1
  • 이미지 #2
iPhone 3G Mute Button Replacement
Difficult
내 문제
I had an issue with intermittent muting of the phone when mute was on. After reading the guide and responses, I decided to give it a try.
나의 수리
The repair went great! Photos were very helpful and gave me the necessary help to replace the button.
My issue was actually due to a cracked housing that holds the mute switch on the inside of the phone, probably damaged in a drop. The housing sheared in half and caused a mis-alignement of the external switch ($4.95 part) and the internal mechanism. After installing the new part, aligning the internal switch, and reassembling it works perfectly.
내 조언
A few pieces that help you when working:
1) A mechanics magnetic bowl. You can pick them up at home depot for around $10 and work great for holding your screws. It reduces the chance of knocking them off of the table.
2) A screw driver magnetizer. It will help greatly when trying to align the small screws.
3) Definitely get the spudger and suction cup from fixit. A must have for undoing the connections and removing the screen.
Spudger 이미지
Spudger
$3.99
Suction Handle 이미지
Suction Handle
$2.95
« 모든 스토리로 돌아가기
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 7
전체 시간: 175
