주요 콘텐츠로 건너뛰기
« 모든 스토리로 돌아가기
Did it - Juhu
jbaur -
iMac Intel 20" EMC 2133 and 2210
스토리 이미지
  • 이미지 #1
  • 이미지 #2
  • 이미지 #3
Removing CCFL from iMac 20in LCD CCFL assembly
3 시간
Difficult
내 문제
Since a view month the upper part of my iMac-Display (mid 2007) was darker than the lower part. Also the the contrast on the complete display was bad. (see first picture)
나의 수리
After the first try, I didn't have the problem on the upper half but on the lower part (changed both, upper and lower CCFLs, second picture). So the next day I opened up everything again and found that I had torn off one of those thin cables soldered to the CCFL during reassembling.
Now the display works as on the first day again. (third picture)
내 조언
After removing the black surround (step 21) DO NOT remove those transparent sheets from the backlight-reflector. So you won't need to clean them before reassemble. Just pull out the CCFL tubes.
During reassembling after putting the LCD back onto the backlight-reflector, be sure to clean off the dust from the top sheet with a soft tissue.
« 모든 스토리로 돌아가기
댓글 1개
good tips, good to know thanks!
David M - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 8
전체 시간: 228
