주요 콘텐츠로 건너뛰기
« 모든 스토리로 돌아가기
Second Repair a Breeze
monodalia -
iPad 3 Wi-Fi
스토리 이미지
iPad 3 Wi-Fi Front Panel Replacement
35 분
Easy
내 문제
Second time I've fixed this.
나의 수리
This time: a easy peasy.
That's because the hard part is removing the screen and knowing where the potential pitfalls are. With a never-before-opened iPad, you have to be extremely patient and carefully loosen that adhesive. You don't want to destroy components inside. Plus, I had to chisel off glass shards last time; this time the damage was a single spider web crack in the center that I just taped over.
The last repair did not make the iPad "refurb worthy" but it worked and looked ok. But as a result, removing the digitizer this time was 2 minutes of applying the iOpener, and some gentle actions with the suction cup to pry it off, then gluing down the new one.
내 조언
If it's the first time you've opened the iPad, slow down, take your time and don't rush that process.
iPad 3/4 Screen Digitizer 이미지
$24.99
« 모든 스토리로 돌아가기
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 3
전체 시간: 118
