주요 콘텐츠로 건너뛰기
« 모든 스토리로 돌아가기
Replaced iPad Air Front Panel
maliawaddell -
iPad Air Wi-Fi
스토리 이미지
  • 이미지 #1
  • 이미지 #2
  • 이미지 #3
iPad Air Wi-Fi Front Panel Assembly Replacement
2 시간
Difficult
내 문제
My iPad had the ghost touching problem, where it just started freaking out and opening apps without being touched. My research pointed to a digitizer problem. I also had a small cracked screen area.
나의 수리
I had mixed results. Eventually I fixed it. Getting the original screen off with all that adhesive was no joke. I also cracked my replacement screen trying to install the home button and had to order another. The home button still doesn't respond as well as the original. But I have a functioning iPad again! So I'll consider it a win.
내 조언
Definitely order the replacement assy that has the adhesive and home button pre-installed. A razor blade and a blow dryer were my main tools used to remove the screen.
iPad Air Screen Digitizer 이미지
$29.99
« 모든 스토리로 돌아가기
댓글 1개
Sounds tricky, but glad you worked it out!
Cynthia Replogle - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 5
전체 시간: 166
