주요 콘텐츠로 건너뛰기
« 모든 스토리로 돌아가기
Ring gen 2 repair
Clutha -
Ring Video Doorbell
스토리 이미지
Ring Doorbell 1st Generation Battery Replacement
40 분
Easy
내 문제
Our door bell failed and on inspection the battery charging socket looked contaminated by moisture. I cleaned it but the unit would only stay online for about an hour then indicated loss of WiFi
나의 수리
Investigation went well using the guide on removing case.
I noticed the mesh indicated in the picture was displaced and not making contact with plate below it. On pressing it down it seemed to have adhesive on it to hold it in place. When closing the case I put two small pieces of thin packing foam on top of mesh to hold it down. Cover replaced and unit left online in house to help dry out any moisture. We’ve had storms & heavy rain humidity over 95%
Unit was ok for 3 hours so refitted outside
It has been 0degC overnight and it’s still working!
내 조언
You must have good small screwdrivers for case screws, a work mat that holds removed parts
« 모든 스토리로 돌아가기
댓글 3개
This is good, I will save it for future reference.
Ravikant - 답글 공유
Sounds good, it is very helpful.
Shower - 답글 공유
Thank you for this helpful guide!
Juan Colon - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 15
All Time: 415
