주요 콘텐츠로 건너뛰기
« 모든 스토리로 돌아가기
Replacing my front display
silverstefan -
스토리 이미지
  • 이미지 #1
  • 이미지 #2
내 문제
I dropped my iphone on a stone floor (i wasnt drunk i promise...). And i like fiddling with electronics and such so i figured i would try and fix it myself. I mean why spend around $600 on something that you cant have fun with?
나의 수리
During the entire procedure i was sweating like crazy and was in a small state of panic. I did run into a couple of problems with some screws, they're so %#*@ tiny! So my iphone is now 2screws lighter.
Even watching a lot of tutorial videos and all of them saying NOT to pinch the screen cables when inserting the new screen i still did. Luckily nothing bad happened and it still worked.
Reconnecting all the cables to the motherboard went much easier than i though it would which was lucky cause i was nervous about that part.
Once i got it all back together and started it up, i was so relieved but then i noticed that my reception had gone down conciderably. I opened it back up after reading up about it and noticed i hadn't connected the small "speaker" cable correctly. The one that connects near the battery connector. Apparently that one has to do with reception as well.
내 조언
Keep track of your screws! And don't do this on a table above a "hairy" carpet...
Watch for that cable near the battery connector, it was tricky to reconnect. Make sure it really clicks in and cant be wiggled.
Spudger 이미지
Spudger
$3.99
Phillips #00 Screwdriver 이미지
$5.49
Flathead 3/32" or 2.5 mm Screwdriver 이미지
$5.49
Tweezers 이미지
« 모든 스토리로 돌아가기
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 11
전체 시간: 65
