주요 콘텐츠로 건너뛰기
« 모든 스토리로 돌아가기
Power supply replacement
lazzeostergaard -
스토리 이미지
  • 이미지 #1
  • 이미지 #2
  • 이미지 #3
내 문제
I bought an Imac 24 on the Swedish ebay "Tradera" guessing that there was a problem with the power supply. Thanks to the guide here on ifixit I thought that I give it a try so I ordered a new power supply, 3 screwdrivers and suction cups.
나의 수리
Thanks to the guide on ifixit i managed to replace the power supply in half an hour. I was very excited when I first pressed the power button and I could here the apply startup sound, however, the power supply was not the only part that was corrupt. The hard drive was also bad so I had to take the Imac apart one more time to replace the hard drive (had one 1 TB laying around).
내 조언
It is a good idea to be 2 persons doing this repair. If one can hold the LCD you don't even need to disconnect the LCD. That will save you some time.
T6 Torx Screwdriver 이미지
T6 Torx Screwdriver
$9.99
Heavy-Duty Suction Cups (Pair) 이미지
$16.95
TR10 Torx Security Screwdriver 이미지
$5.99
« 모든 스토리로 돌아가기
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 17
전체 시간: 57
