주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. LG Watch Urbane 수리는 저희 서비스 설명서를 사용하십시오.
  1. LG Watch Urbane Teardown, LG Watch Urbane Teardown: 1 단계, 이미지 1/2 LG Watch Urbane Teardown, LG Watch Urbane Teardown: 1 단계, 이미지 2/2
    • Urbane legend has it that this is the first smartwatch to closely resemble a traditional watch, rather than a wearable smartphone. Let's see what else this timepiece has to offer:
    • 1.3-inch 320 x 320 (~245 ppi) P-OLED display
    • 410 mAh battery
    • Snapdragon 400 processor with 1.2 GHz Quad-Core Cortex A7
    • 512 MB RAM and 4 GB storage
    • 9-axis combination (Gyro + Accelerometer + Compass)
    • Bluetooth 4.1 Low Energy
  2. LG Watch Urbane Teardown: 2 단계, 이미지 1/3 LG Watch Urbane Teardown: 2 단계, 이미지 2/3 LG Watch Urbane Teardown: 2 단계, 이미지 3/3
    • Barring the dark watch face, this device could certainly be mistaken for a mechanical watch, until you flip it over...
    • The rear of the watch features a heart rate sensor, charging dock contacts, and the model number (LG-W150).
    • While the Urbane eliminated a handful of face options included in the LG G Watch, this timepiece introduces plenty of faces to choose from.
    • The Urbane's 245 ppi display looks a lot better in person than under our camera—there seems to be a moiré effect that makes the pixels stand out.
    • However, it's still not quite as sharp at super-close distances as the Apple Watch, with its 290 ppi (for the 38 mm, 302 for the 42 mm) screen.
  3. LG Watch Urbane Teardown: 3 단계, 이미지 1/2 LG Watch Urbane Teardown: 3 단계, 이미지 2/2
    이 단계에 사용된 도구:
    $3.99
    구매
    • The 22 mm standard leather watch band can be swapped out for other bands of various colors and materials.
    • Our handy pointy angled tweezers are once again invaluable spring bar removers.
    • Removing the band exposes a couple of ports, likely for the microphone—or microphones?
  4. LG Watch Urbane Teardown: 4 단계, 이미지 1/3 LG Watch Urbane Teardown: 4 단계, 이미지 2/3 LG Watch Urbane Teardown: 4 단계, 이미지 3/3
    • The last time we tore down an LG smartwatch, we were pleased to find screws securing an o-ring sealed rear door. Today we're heating our iOpener and feeling a little sad.
    • However, thanks to a handy pry notch, things aren't too bad. But you will need to replace the adhesive before re-sealing the watch, to maintain that IP67 water resistant rating.
    • IP67 is a water and dust resistance rating that guarantees the device to be dust-tight, and able to survive submersion in 1 meter of water for 30 minutes.
  5. LG Watch Urbane Teardown: 5 단계, 이미지 1/3 LG Watch Urbane Teardown: 5 단계, 이미지 2/3 LG Watch Urbane Teardown: 5 단계, 이미지 3/3
    • Apart from the glue, the rear case comes away nice and clean—no cables, no booby traps. We like it.
    • Power from the charger feeds through the rear case onto a tidy row of spring contacts beside the motherboard.
    • Speaking of the motherboard, it's time to start digging out the Urbane's silicon. Starting with the battery, we flick away a few cable connectors and twist out the tiny watch-sized screws.
    • Happily, these are totally ordinary (albeit tiny) Phillips screws—none of that sketchy tri-wing business you find in so many flashy smartwatches these days.
  6. LG Watch Urbane Teardown: 6 단계, 이미지 1/2 LG Watch Urbane Teardown: 6 단계, 이미지 2/2
    • We peel the motherboard out of the chassis to get a better look at this wearable's hardware:
    • SK Hynix H9TU32A4GDMC-LRKGM 512 MB mobile DDR2. The Qualcomm Snapdragon 400 SoC is hidden beneath this DRAM device.
    • Qualcomm PM8226 power management IC
    • Broadcom BCM4343 integrated communications module
    • Texas Instruments BQ27421-G1 battery fuel gauge
    • Single microphone (Knowles) —we're not sure why there were two ports; maybe just symmetry?
    • Vibrator motor—soldered in place on the motherboard
  7. LG Watch Urbane Teardown: 7 단계, 이미지 1/1
    • And on the flipside:
    • Synaptics S3526B touch controller
    • Invensense MPU-6515 6-axis accelerometer and gyro
    • Asahi Kasei AK8963 3-axis compass IC
    • Qualcomm WCD9302 audio codec
    • PixArt PAH8001 heart rate sensor
    • Alps HSPPAD038 pressure sensor
    • Imagis ISA1000 haptic driver
  8. LG Watch Urbane Teardown: 8 단계, 이미지 1/3 LG Watch Urbane Teardown: 8 단계, 이미지 2/3 LG Watch Urbane Teardown: 8 단계, 이미지 3/3
    • With a quick twist of our opening pick, we remove the battery faster than a mariachi player running through his scales.
    • The Urbane rocks a 410 mAh battery—just like its primo, the LG G Watch R.
    • The Moto 360 and Samsung Gear Live pack 300 mAh batteries, while the Apple Watch gets by on a mere 205 mAh cell.
  9. LG Watch Urbane Teardown: 9 단계, 이미지 1/3 LG Watch Urbane Teardown: 9 단계, 이미지 2/3 LG Watch Urbane Teardown: 9 단계, 이미지 3/3
    • Two screws and some mild adhesive are all that stand between us and picking out the plastic midframe.
    • As devices shrink, manufacturers are turning to adhesive instead of screws or clips.
    • On the whole, this has been bad news for repairs—but in this case, LG seems to have found the secret recipe that balances construction strength with pry-ability.
    • Picking out the watch's midframe reveals a single cable responsible for the crown button and charging cradle ports, and a pair of spring contacts that connect the motherboard to the watch body, perhaps to use the body as an antenna.
  10. LG Watch Urbane Teardown: 10 단계, 이미지 1/3 LG Watch Urbane Teardown: 10 단계, 이미지 2/3 LG Watch Urbane Teardown: 10 단계, 이미지 3/3
    • Our iOpener tags in to help dispatch the P-OLED display.
    • This incredibly thin display appears to be made up of several layers, that need to be peeled up off the back of the glass in order to remove the glass.
    • As we peel up the display a strange, stretchy membrane sticks to the back of the digitizer.
    • This membrane is definitely serving as an adhesive between the display and the digitizer, but may also serve some higher purpose as a thin film.
  11. LG Watch Urbane Teardown: 11 단계, 이미지 1/3 LG Watch Urbane Teardown: 11 단계, 이미지 2/3 LG Watch Urbane Teardown: 11 단계, 이미지 3/3
    • Peeling up the display
    • Now that it's free of the case, we can get a closer look at the Urbane's 245ppi P-OLED screen.
    • If you think this display looks familiar, we're right with you. LG says they built the Urbane around the display used in the LG G Watch R.
    • Right below the screen, we find an LG Innotek LGS32057-05-0547 POLED display driver.
  12. LG Watch Urbane Teardown: 12 단계, 이미지 1/3 LG Watch Urbane Teardown: 12 단계, 이미지 2/3 LG Watch Urbane Teardown: 12 단계, 이미지 3/3
    • The next layer off the screen sandwich is the digitizer. Also held in with sticky adhesive on both sides, it bears the LG Display co., Ltd marking.
    • LG produces their own displays for their gadgets—something not every manufacturer is able to do.
  13. LG Watch Urbane Teardown: 13 단계, 이미지 1/3 LG Watch Urbane Teardown: 13 단계, 이미지 2/3 LG Watch Urbane Teardown: 13 단계, 이미지 3/3
    • We put our curved blade to work, and pop out the display glass.
    • The glass floats away intact, in all its perfect circularness, and the last layer of the display—which looks like a polarizing film—peels off, leaving behind some gooey optically clear adhesive (OCA) residue.
    • Unfortunately, it seems like the procedure we just endured is the only way to replace a cracked screen—the display and digitizer are adhered to the back of the glass after it is installed in the watch body.
    • That means to replace a cracked glass you'll have to remove all of the pieces of the display, install a new glass front, and then adhere a new OLED display to the back of the glass with OCA.
  14. LG Watch Urbane Teardown: 14 단계, 이미지 1/2 LG Watch Urbane Teardown: 14 단계, 이미지 2/2
    • LG Watch Urbane Repairability Score: 7 out of 10 (10 is easiest to repair)
    • Once you're inside, the motherboard is very easy to remove—three Phillips screws and a few connectors.
    • With the motherboard out, the battery is very easy to replace; only mild adhesive holds it in.
    • Features a standard 22 mm band secured with spring bars—replacement and style swaps are easy.
    • Glued back requires heat and prying to open, and replacement adhesive to properly re-seal.
    • Because the display is adhered to the back of the front glass, which is removed from the front, screen replacement is very difficult and will require re-adhering the display layers.
댓글 16개
So is this exactly the same as the GWR then?
James Kemble - 답글
Yup, here's a list of the parts found in the g watch r:
SK Hynix H9TU32A4GDMC-LRKGM - PoP 512 MB LPDDR2 + 4 GB eMMC
Qualcomm PM8226 - Power Management IC
Qualcomm WCD9302 - Audio Codec
AKM AK8963 - Compass IC
Synaptics S3526B - Touch controller
InvenSense MPU-6515 (?) - 3 axis gyro and accelerometer
Broadcom BCM4343WKUBG - Bluetooth 4.2 and WiFi b/g/n
Jolan Rensen -
Interesting teardown. Did the display and digitizer survive the process? Were you able to put them back together?
Richard Baguley - 답글
Just replace the entire case with the display, it's pointless to peel them apart.
Tom Chai -
What is the front glass made out of?
David S - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 13
전체 시간: 56,003
