주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. WoW Server Blade 수리는 저희 서비스 설명서를 사용하십시오.
  1. WoW Server Blade Teardown, WoW Server Blade Teardown: 1 단계, 이미지 1/2 WoW Server Blade Teardown, WoW Server Blade Teardown: 1 단계, 이미지 2/2
    • Ever wondered what fuels the World of Warcraft? Well wonder no more, iFixit has gracefully acquired an old retired WoW Server Blade.
    • This particular server blade is an HP ProLiant BL25p that Blizzard decked out with a commemorative plate. Wow.
    • This is one of several server blades sustaining the Altercac Mountains from January 4, 2007 till July 21, 2010.
    • The commemorative plate also bears the signatures of many of the key WoW developers.
    • Before we proceed any further, we would like to apologize for any future bad WoW puns and jokes. Trust us, there will be many.
  2. WoW Server Blade Teardown: 2 단계, 이미지 1/1
    • The transparent panel covering all the mechanical madness inside the server blades provides shoddy protection, but is nonetheless ornate.
    • -10% armor. +15% intellect.
  3. WoW Server Blade Teardown: 3 단계, 이미지 1/2 WoW Server Blade Teardown: 3 단계, 이미지 2/2
    • How much RAM does it take to create the high peaks that rise up north of the Hillsbrad Foothills? It seems the magic number is six.
    • Although there are a total of 8 RAM slots in the server blade, this model only fills six of them.
    • There are four 512 MB and two 2 GB PC-3200 DDR modules.
  4. WoW Server Blade Teardown: 4 단계, 이미지 1/1
    • Memory IC Identification (only 1 is labeled of each):
    • Texas Instruments SN74SSTVF16859 13-26 bit registered buffers
    • Microchip (formerly Microchip) AT34C04 4 Kb serial EEPROM
    • Samsung K4H510438C-ZCCC 512 Mb DDR SDRAM
    • Renesas (formerly ICS) ICSLP857AKL registered buffers (likely)
    • SK Hynix DDR SDRAM
  5. WoW Server Blade Teardown: 5 단계, 이미지 1/2 WoW Server Blade Teardown: 5 단계, 이미지 2/2
    • This is highly reminiscent of the classic pull my finger bit—but then again who can resist such a request? Fine...pull we will.
    • We were expecting Frost Wolves, but instead we found a hard drive data cable connector.
  6. WoW Server Blade Teardown: 6 단계, 이미지 1/2 WoW Server Blade Teardown: 6 단계, 이미지 2/2
    • Twisting a few knobs is all that is required to remove the SCSI controller from the motherboard.
    • HP Part Number 355895-002
    • The SCSI contoller (pronounced "scuzzie"), is responsible for interfacing with a whole number of things: hard drives, scanners, tape drives, and other alliance technologies.
  7. WoW Server Blade Teardown: 7 단계, 이미지 1/1
    • SCSI Inteface IC Identification:
    • HP 244651-002 processor (likely)
    • Macronix parallel NOR flash memory
    • Microchip (formerly Atmel) AT24C02AN and AT24C08AN 2 K and 8 K serial EEPROM memory
    • Analog Devices ADM3202A High Speed RS-232 2-ch. interface controller
    • Texas Instruments (formerly Unitrode) UCC5672PWP 2.7 - 5V multimode terminator
    • ON Semiconductor (formerly Fairchild) MC74LCX08 quad AND-gate
    • ON Semiconductor (formerly Fairchild) LM1597AN linear regulator
  8. WoW Server Blade Teardown: 8 단계, 이미지 1/3 WoW Server Blade Teardown: 8 단계, 이미지 2/3 WoW Server Blade Teardown: 8 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Coin
    $2.99
    구매
    • We had to mine deep into our pockets to acquire the proper tools for removing the power filter.
    • We were hoping that we could sell this wonderful item afterwards, but it's only worth 25 cents.
    • The DC Power filter has an input of -43 V ~ 57 V at 13 A max. That's 546 watts of maximum power!
    • Since this is just a power filter and not a transformer, the output is almost the same: -43 V ~-57 V at a maximum of 12.4 amps.
    • There's a Texas Instruments (formerly National Semiconductor) LM35CIM3 temperature sensor on-board to monitor the temps.
  9. WoW Server Blade Teardown: 9 단계, 이미지 1/3 WoW Server Blade Teardown: 9 단계, 이미지 2/3 WoW Server Blade Teardown: 9 단계, 이미지 3/3
    • Once all the server juice has been filtered by the power filter, its gets converted to the correct voltage by the power converter.
    • The power converter is actually two identical modules stacked on top of each other, using the standoffs between them as a power relay.
    • The output of the power supply is 12 volts, 40 amps, for a whopping 480 watts.
    • As for chips, we find:
    • STMicroelectronics LM339 quad voltage comparator
    • Renesas (formerly Intersil) HIP2100 high frequency half-bridge driver
    • Texas Instruments (formerly Unitrode) UCC2808-1 low power PWM controller
    • Renesas (formerly NEC) PS2701-1 optocoupler
  10. WoW Server Blade Teardown: 10 단계, 이미지 1/2 WoW Server Blade Teardown: 10 단계, 이미지 2/2
    • In the World of Warcraft, the Alterac Mountains are located somewhere between the Western Plaguelands and Hillsbrad, but they are stored right here on these hard drives.
    • Well, not these hard drives in particular. Blizzard probably wanted to keep all their data handy, so this server blade just comes with blanks.
    • The WoW server blade has two dedicated hard drive bays.
    • It seems "A device or blank must occupy all bays during operation."
    Because of the airflow
    daniel.elss - 답글
  11. WoW Server Blade Teardown: 11 단계, 이미지 1/3 WoW Server Blade Teardown: 11 단계, 이미지 2/3 WoW Server Blade Teardown: 11 단계, 이미지 3/3
    • How do you keep the snow from melting off the Ruins of Alterac? With eight—count 'em, eight—fans.
    • Each pair of fans draws .95 amps at 12 volts, for a total power rating of 85.2 watts. That really blows.
  12. WoW Server Blade Teardown: 12 단계, 이미지 1/3 WoW Server Blade Teardown: 12 단계, 이미지 2/3 WoW Server Blade Teardown: 12 단계, 이미지 3/3
    • It looks like they threw everything—including the kitchen heat sink—at keeping those AMD processors cool.
    • Each dual-core AMD Opteron 275 processor provides 2.2 GHz of processing power.
  13. WoW Server Blade Teardown: 13 단계, 이미지 1/2 WoW Server Blade Teardown: 13 단계, 이미지 2/2
    • What sort of sorcery is this? Worry not, our trusty T15 Torx screwdriver will slay any beast that stands in the way of removing the motherboard.
    • Huzzah! Have at thee ogre! We have conquered the mighty motherboard beast! Victory is ours!
  14. WoW Server Blade Teardown: 14 단계, 이미지 1/1
    • The frontside of the motherboard:
    • Broadcom BCM5704CKFB Ethernet controller
    • ATI Technologies Rage XL 215R3LASB41 graphics (VGA)
    • Compaq 170095-002 server controller
    • Pulse H5007 1000BASE-T magnetic modules
    • AMD NetPHY AM79C874VC low power ethernet transceiver
  15. WoW Server Blade Teardown: 15 단계, 이미지 1/1
    • IC Identification, continued:
    • Renesas (formerly ICS) ICS950402AFLF AMD system clock
    • Renesas (formerly ICS) ICS853031AY Differential/2.5 V / 3.3 V LVPECL/ECL fanout buffer
    • Microchip (formerly Atmel) AT24HC02BN and STMicroelectronics serial memory
    • Texas Instruments MAX3243C RS-232 line driver/receiver w/ ESD protection
    • Diodes Incorporated (formerly Pericom) PI5C3253QE dual 4:1 mux/demux analog switch
    • Diodes Incorporated (formerly Pericom) PI3C3125LE 4-Bit High-Bandwidth Bus Switch and Maxim Integrated MAX696EEE microprocessor supervisory circuit
    • Texas Instruments LM358 dual operational amplifier
  16. WoW Server Blade Teardown: 16 단계, 이미지 1/2 WoW Server Blade Teardown: 16 단계, 이미지 2/2
    • The Ruins of Alterac! Or, the ruins of a server that hosted part of Alterac.
    • WoW Server Blade (HP ProLiant BL25p) Repairability Score: 10 out of 10
    • No security screws
    • Modular, easy to access components
    • HP provides online maintenance repair documentation.
    • It should be noted that these server blades are designed to be easily maintained and eventually disposed of.
    • We really appreciate HP being so mindful of the repair and maintenance aspect of their products.
Walter Galan
694,692 평판
안내서 1,203개 작성하였습니다
댓글 9개
Cool! I'm not a WoW player but still, a studio giving away servers! Sweet!
Kendall Bartling - 답글
The HP ProLiant are very powerful servers!
Eneider Colina - 답글
didnt know that wow had server products
Cool
remliv - 답글
I have 10 of these… 5 from the U.K. and 5 from the U.S. … Picked them up during the auction 7 years ago… All still in the original shipping cartons… Interest…? I need to sell them now… I also have 30K trading cards, and lots of good loot cards… Swift Spectral tiger, and such… My toon has a Mini Tyrel from the Paris show…
dstarek - 답글
Which servers do you have dstarek, like for which realms and realistically what’s the pricing per server you’re seeking?
Priers -
How much are you looking to get rid of a US server for if you still have them? Would like to get in touch.
Kevin G -
How much you wan’t for one?
poul -
I just ordered the latest ones for the 15 years anniversary. They were used from 2010 to 2016 I wonder if I could bring it back up running :D
daniel.elss - 답글
Ordered one as well, curious if there's a way to make it function with my own drives but I mainly want it as a collectors piece.
Kevin G -
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 21
30일 전: 89
전체 시간: 33,317
