DYMO® LetraTag®
DYMO® LetraTag® 라벨 메이커는 가정이나 사무실에서 사용하도록 설계되었습니다. 휴대용 LetraTag® 200B, LetraTag® 100H, LetraTag® 100T 및 LetraTag® 100H Plus를 확인해 보세요.
지난 24시간: 2
지난 7일: 20
지난 30일: 87
전체 시간: 896
댓글 2개
Please advice, I disassembled the machine, and found a loose spring. I found out that the spring is used to retract the cutter after cutting. But I can't figure out the correct placement of the spring. Does anyone know? It is the handheld version.
Lemonoius - 답글 공유
Now I know. Disassemble completely the cutter handle and remove the white part. Then remove the circuit board part from the tape holder. Then the cutter mechanism will come out, and the spring belongs inside the part the blade is fastened to. Use this video to disassemble. https://www.youtube.com/watch?v=UoRt52zM...
Lemonoius - 답글 공유
