학생-기여 위키
자사 교육 프로그램의 멋진 학생들이 이 위키를 만들었습니다.
Distorted audio or no audio
Audio sounds fuzzy/distorted, or doesn't play at all.
Loose Speaker Membrane
Furby's speaker membrane can loosen over time, lowering the quality of audio or even disabling audio all together. If there is still some audio, the membrane is likely loose and needs pressure applied to it.
Broken Speaker
Furby's speaker may also be broken entirely, in which case all audio will be gone and replacing the speaker will be necessary.
Furby’s “feet” immobile
Furby won't move correctly or at all.
Feet are dirty
Furby's feet may accumulate grime over time, which prevents proper movement. If this occurs it is necessary to clean your Furby. Simply open up the base of the furby as if you were changing the batteries. Once the battery hatch is removed, you just need to clean the hatch where the feet are and Furby should move normally again.
Device not powering on
Furby is unresponsive when batteries are in.
Reset Button
Before removing any components, try the reset button located near the battery carriage. Remove the base of the Furby and near the batteries will be a small button with a sticker next to it stating "Refresh ->".
Battery Acid
If pressing the reset button didn't return power to the device, then check to make sure battery acid hasn't destroyed the battery coils.
댓글 2개
I have a 2012 yellow Furby that works ok when it’s on but it’s doesn’t want to stay awake. Also it changed personalities and I have tried to reset it and it won’t change back. I don’t know how to fix this. Anybody have a clue?
ccupcat - 답글
Try and do factory reset by flipping the furby upside down, pull its tail and press on tongue all at the same time.
Anne Khairi - 답글
