주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2193 질문 전체 보기
Why does my iPhone 4s screen show black and blue lines?
My iPhone screen shows only black and blue vertical lines. The screen is not cracked, and still responds to my touch. I've already tried restoring it on iTunes, and I did a hard reset (holding the home and lock button until it turns off and back on).
What parts of the phone do I need to replace to get the display working again?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 31
댓글 3개
vicky how much will it coast
lauren norledge, sorry looks like Vicky hasn't been here since Aug 21,2012. The assembly will cost you anywhere between $35 and $100 depending on where you purchase it from.
that still didnt work for me George.... and i need this fixed or my mom will kill me. not literally but yea
댓글 달기
답변 6개
선택된 답변
Vicky, your front display consist of multiple pieces. In your case the digitizer (glass) is still intact, but your LCD is no longer working. I suggest that you change the display assembly. Here is the guide for it. The assembly is available right here as well as many other places. Hope this helps, good luck.
iPhone 4S Screen 이미지
상품
iPhone 4S Screen
$34.99
해당 답변은 도움이 되었습니까?
점수 6
댓글 1개:
Thank you, I'll replace it as soon as possible :)
댓글 달기
Try pressing the home and power button at the same time but holding it down until it shows the apple sign. If that doesn't work you can rest your iPhone before sending it back for a replacement.
1- Hold down the home and sleep/wake button at the same time (In order to power off that way)
2- Once you were able to power off, next hold down on the home button and at the same time plug the USB cable into the phone and computer. Keep holding the home button until a message factory settings. It will take a few minutes for it to appear.
3- Once it does click on restore.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
mine has done the same thing. im really worried that it might not work anymore. ive already cried today about it. what should i do ~ Aiyana Irving
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
i need help to and it does not work
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Dropped my iPhone today and the screen didn't break, but blue and balck vertical lines show up when i press buttons. I have a lot of important text messages and pictures that i don't want to lose. My phone is still responsive but continues to only show blue and black lines on screen. Very worried and need help!!
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
plz i have the same issue. how you fixed it ?
댓글 달기
You should follow the screen repair guide to replace the screen.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Vicky 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 22
전체 시간: 197,859
