주요 콘텐츠로 건너뛰기
MacBook 제품군은 2006년 5월에 처음 소개되었으며 Apple의 가정용 노트북 iBook을 대체하였습니다.
20 질문 전체 보기
Internal sound not working.
I have tried everything but im having no joy. Sound plays ok through headphones but soon as i unplug them I get NO sound coming from the built in internal speakers.
Please Help.
Big Thanks
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 1개
third time you asked the same question in 7 hours
댓글 달기
답변 2개
선택된 해법
Could you boot the MacBook from an external source to verify if the problem is hardware or software issue ? Check the headphones port with a flashlight. What is the system preferences -> sound panel -> output status ? Also, repairing permissions can sometimes fix a sound problem.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Beat me by 27 seconds--+1 for a good answer. Ralph
댓글 달기
Two possibilities come to mind. 1. The speaker connection to the logic board is faulty or 2. the headphone jack has a problem and is not connecting the speakers when you remove the headphones. You can try looking at the jack without removing the top cover but I suspect you will need to take it apart. Ralph
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
Could be a broken tip on the audio jack. +vote for the good "late" answer
With a broken tip inside the sound port the OP would have no heaphones sound and he says that << sound plays ok through headphones>>.
댓글 달기
답변을 추가하세요
Mark 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 909
