Internal sound not working.
I have tried everything but im having no joy. Sound plays ok through headphones but soon as i unplug them I get NO sound coming from the built in internal speakers.
Please Help.
Big Thanks
좋은 질문입니까?
기기에 대한 안내서, 부품 및 답변에 신속히 접근할 수 있습니다
iFixit은 쿠키를 사용하여 사이트 기능을 개선하고 트래픽을 분석하며 광고를 개인화합니다. 당사 사이트를 사용함으로써 귀하는 당사의 쿠키 사용 및 개인정보 취급방침에 동의하게 됩니다.
Please Help.
Big Thanks
좋은 질문입니까?
Could you boot the MacBook from an external source to verify if the problem is hardware or software issue ? Check the headphones port with a flashlight. What is the system preferences -> sound panel -> output status ? Also, repairing permissions can sometimes fix a sound problem.
이 답변이 도움이 되었나요?
Beat me by 27 seconds--+1 for a good answer. Ralph
Two possibilities come to mind. 1. The speaker connection to the logic board is faulty or 2. the headphone jack has a problem and is not connecting the speakers when you remove the headphones. You can try looking at the jack without removing the top cover but I suspect you will need to take it apart. Ralph
이 답변이 도움이 되었나요?
Could be a broken tip on the audio jack. +vote for the good "late" answer
With a broken tip inside the sound port the OP would have no heaphones sound and he says that << sound plays ok through headphones>>.
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 909
댓글 1개
third time you asked the same question in 7 hours
mayer 의
