주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2011년 11월에 출시된 Barnes & Noble의 7인치 멀티미디어 태블릿입니다. 수리가 간편하며 간단한 지렛대 도구와 스크루드라이버만 있으면 됩니다.
My nook won't charge.
Is there a way to replace the power input on the bottom of the unit? When I plug in the power cord it doesn't sit properly. I bought a new cable and have the same issue.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 21
댓글 9개
I also have this problem. I am now the proud owner of 3 cables but the unit does not charge
의
My phone goes to green for four to five seconds then orange for one to three seconds and go off... ill leave it on charge and it will start flashing red on and off ... I dont understand why
의
I have the same problem (green yellow and red). My nook does not have the same back panel as shown in the tutorial, there's no corner piece to lift. Any ideas?
의
yours is probably a newer one or a different size, if your start at the front lower left corner and lift the bezel off you will see from that point on it is the same instructions as the video
의
my Nook is the HD Model from about 5 years ago and it is my favorite toy! is there any help for this model?? I am having the same problems as listed aboveand I JUST PURCHASED my 3 power cord yesterday. Thanks for any help
의
댓글 4개 더보기
댓글 달기
답변 2개
가장 유용한 답변
I wanted to go on my tablet/nook and it wouldn't turn on. when i plugged it in it goes green for a couple of seconds and it went orange for about 5 seconds and went off, i have left it over night and see if it could get enough power to turn on and it didn't i even put it on charge for 2-3 months.
i left it for a day and i plugged it back in and it stayed green for about 3-4 minutes and turned off again because i had it at a angle.
my dad bought a new nook charger lead and hopefully it works.
이 답변이 도움이 되었나요?
점수 4
댓글 2개:
This happening to me too.Its so frustrating.I might visit Barnes & Nobles to see what they can do.
의
It seems to be a big problem for this model Nook. I am looking for a new charging port and I hope that's all it will take to fix it.
의
댓글 달기
Anthony, here is the teardown for the Nook Tablet. It does show you how to get to the connector. It appears to be soldered to the board. Once you have the tablet apart, you may have to scour places like mouser.com or digikey.com to find a match for the part.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Anthony 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 12
지난 7일: 22
지난 30일: 56
전체 시간: 23,037
