주요 콘텐츠로 건너뛰기
Model No. A1367 / 8, 16, 32, or 64 GB capacity
20 질문 전체 보기
How do you change the back plate
I want to change the back plate on my ipod touch 4 gen and can't seem to find out how. It does not have any screws.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 4개
선택된 해법
Jane Thomas, there are plenty of screws that keep it all in place :-) Check this guide, it'll get you close to the back plate. Lots of work and a bit of a PITA to do it. Keep all the screws marked so as to know where they go back into. Here is the complete teardown, it is not a guide, but should show you the extend of the work needed to replace the back. Hope this helps, good luck.
iPod Touch 4th Generation 이미지
안내서
iPod Touch 4th Generation Teardown
난이도:
조정
iPod Touch 4th Generation Volume/Power Button Cable 이미지
안내서
iPod Touch 4th Generation Volume/Power Button Cable Replacement
난이도:
매우 어려움
35 - 40 minutes
이 답변이 도움이 되었나요?
점수 1
댓글 달기
가장 유용한 답변
Replacing back case without tearing the button flex cable is extremely difficult since in the factory the cable is installed into the case first, then soldered onto the board after the board is installed. The ifixit guide made it backways because they tried to pull everything out. If you can do soldering, then refurbishing this device is much easier and straightforward.
I consider replacing the case of iPod touch 4 as complete refurbishment because it is simply too difficult to just replace the back case. Discard the old battery, copper adhesive and flex cable, buy new ones and putting them together is more worthy of the effort and actually easier.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Everything is taken out from the front side. There are guides on this website. It is also not an easy repair to attempt.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Check out these videos on Youtube:
Back Housing Replacement iPod Touch / Full Disassembly / Taking Apart - 4th Generation
http://youtu.be/0ScpTGGqb3U
Back Housing Replacement - iPod Touch 4th Generation - Part 2
http://youtu.be/SBRfagwk4II
It might be helpful to see how it's done step by step.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Jane Thomas 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 5,397
