주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
탑승형 잔디 깎는 기계. 제로 턴 반경 잔디 깎는 기계, 50인치 커팅 데크, 유압식 자동변속기.
mower deck will not engage when the PTO switch is turned on?
When the PTO switch is turned on the mower deck does not come on. I have replaced the PTO switch but it still does nothing. Could the electric clutch be bad?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 24
댓글 23개
Mower will engage but will not drive foward or reverse even without mover engaged
의
I have the same problem. When I engage PTO switch mower blades wont turn. I hard wired from battery to electric clutch and mower blades came on, so that I know its not my clutch or adjustment. Replaced switch and it still didn't work. Please help.
의
There's a yellow wire hanging under the front of my scott riding mower. The desk isnt engaging. I've changed the pot switch. Now the yellow wire has power to it. But I dont know where it goes. Someone cut it.
의
I'm having the same issues, every time I engage PTO switch, I blow the fuse and mower shuts down.
I replaced the pto switch and the same thing happened. So i disengaged the pto clutch connection (yellow insulated wires ) or harness and I can pull PTO and she doesn't blow any fuse and she stays running????? This is a Scott's 2048. And the clutch smells like it's burning up and is throwing small shards of metal and plastic. I just want someone knowledgeable to confirm electric clutch needs replacing because they are about $300.
의
@jshockley56 I have a scotts2048 so I might be able to help you track it down off of mine
의
댓글 18개 더보기
댓글 달기
답변 12개
선택된 해법
Chris, first try to adjust the clutch. I attached some images from the manual. check the wiring. If the wiring does not reveal any problem and a clutch adjustment does not resolve it, it may be time to replace the clutch. Also check on here. Hope this helps, good luck.
이미지
이미지
이미지
이 답변이 도움이 되었나요?
점수 10
댓글 24개:
I replaced the clutch and it's working great. Thanks
의
You are welcome :-)
의
this is not an electric clutch, but a manual one
의
I have same problem but when I turn pto it try's to engage I can hear and see somethings working upper side of clutch but nothing to the belt pully
의
댓글 19개 더보기
댓글 달기
My charging system was not working correctly. The battery was too weak to engage the blades. Tired of charging the battery often and no time to work on the mower, I purchased a 1.5W solar trickle charger from Harbor Freight for $14 that I leave connected.
My battery now keeps a full charge and have not had any starting or blade problems for 6 months.
https://www.harborfreight.com/15-watt-so...
이 답변이 도움이 되었나요?
점수 4
댓글 3개:
I had mine on the charger for several days before I serviced it. I like to fully charge it after putting it back into the mower. I take it out in the winter and put it on a maintain setting for the winter. It had 13.8 volts when I moved it into the shop from the storage shed, and was running 14.0 approx when running at an idle. Does anyone know what the voltage at the harness should be? (the disconnect beside the engine going to the clutch?) I have hard a weak battery before, and agree, the clutch didnt engage then.
의
My pto clutch kicks in blades turn and they shut off does it need adjustments Sears ridwr5
의
Thank you Low Charge !! You saved me from buying and installing an unnessacary clutch. Tested the switch and was certain it was the clutch even though I had jumped the battery to get it started. Just need a kick in the pants to open my eyes.
Thank you, thank you, thank you.
의
댓글 달기
I see you have fixed your problem but FYI to anyone reading this, I had the same issue with the mower not engaging and found the normally open contact on the mower deck engage button was bad. it was around $30 bucks to replace the button. I Needed a continuity checker to test and find this issue.
이 답변이 도움이 되었나요?
점수 3
댓글 5개:
where was that button
의
What keeps the top half of the clutch from spinning with the bottom pulley
의
Snapper Z1401K new clutch new switch clutch kicks on when starting still does not engage?
의
My zero turn turned the bades on while I was going down the road. And now they wont shut off. And when I do shut off the mower it is hard to crank. Then the blades come on again, any sugestions
의
Bad switch, or wires are switched on pro switch. Meaning on is off, and off is on. Try this first. Check safety switch . What kind of mower do you have. I truly believe your switch is shot or the off /on switch are reversed. Let me know if it helped
의
댓글 달기
g'day every one,this may sound a bit unsafe but before you go and get a new PTO switch,or a new clutch, hot wire the clutch, run it to a on/off switch(you have to put the switch on your self)leave your PTO switch off(down not up) start the mower turn the new switch(hot wire) on and leave PTO switch off,if deck works you can mow even in reverse but rember the switch keeps the deck going all the time till you switch it off .then you can have a lecky check your wiring as it won't be your clutch,but you can get your lawn cut.
이 답변이 도움이 되었나요?
점수 3
댓글 3개:
My ingage button blows a fuse wen i try to ingage the the blades.
의
My pto will turn the blades off after 2 minutes the relay for the pto under dash is getting hot is that my problem?
의
At full throttle when I engage my PTO, the mower will spit and sputter how to fix this?
의
댓글 달기
Thank you all for pointing me in the right direction.....after much analysis I found the reason my battery was not charging and that my clutch was operating sporadically was due to a partially broken wire between the alternator and the regulator. Make sure when inspecting your wire harness you give your wires a firm tug; had I not done this I never would have realized the wire was 'hanging by a thread'. It broke loose in my hands right where the wire meets the connector between the two components. Stress fatigue....just like me lol
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I put a new idle belt on my craftsman mower but the clutch won't work,I can switch gears while the clutch is out and have no brakes,what did I do wrong,mine is a manual clutch
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
I have a new holland tz25da.was mowing along just fine and then the blades stopped.should I start with the fluids first?
의
댓글 달기
Having the same problem took PTO switch out and they are two of the little tongs broke off in it any suggestions….
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I have MDT yardman he4160 pto switch works fine and cutter engages but only for short while and blades stop, restart pto switch and they start again fine but keep dropping out. Any ideas please
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I had the same problem... I found one of the wires had rubbed of the plastic coating near the clutch and was grounding out. I put a shrink wrap tube on it and rerouted the wire from where it was rubbing. Haven't had a problem since.
이 답변이 도움이 되었나요?
점수 0
댓글 3개:
What reasons are there for my pto clutch starting up and running fine for about 5 minutes then the blades just stop .
I put a new pto clutch on and still same problem .
Any help would be appreciated.
의
which wire on the clutch is the hot wire
의
Pto would not engafe on riding lawn mower replaced switch and it wont start says pto is engaed on or off put old one back in and it starts but wont engage
의
댓글 달기
Husqvarna RX5424 Last year we had some issues with it not wanting to start, but it was the seat switch out of place, and
Kept blowing the fuse under the seat. Its fine now and starts and runs fine.
However, the PTO will not engage. I’ve traced the wires to the pto clutch and switch,
and everything looks fine.
Can you give me some ideas of things to look at?
Is there a fuse or circuit breaker?
It will not start with the PTO engaged (good), but that tells me that there is a good connection somewhere.
I unplugged the switch and plugged it back in.
I unplugged the harness by the engine and cleaned it, it looks good.
Doesn’t look like any other broken wires.
Could it be that seat switch acting up again only not letting PTO start?
I think I will try to hard wire the PTO clutch harness and see if it engages then? Then it has to be a safety switch or PTO switch?
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Battery= Perfect. Ordered switch. The old one worked and then quit again. I got new switch, but before I installed it, I hot wired it, it worked again, w the old switch, it worked.
Wouldn’t work with new switch.
SO, I traced wires to the back again, and the stupid, bad, poor design connector in the back wasn’t making good connection. Cleaned them all, taped them all up, works perfect. The short little adapter pigtail harness from the machine to the PTO connector, and it was shorting out. Installed old switch and all was well. Greased the machine and blades with a synthetic grease, sharpened blades, complete & master tune up and oil change, pressure washed, mowed for 2 hours with it, and it was fine.
I will wire the adapter directly to the harness w solder shrink tube butt connectors, should have been in the first place.
Ordered another set of Gator blades, a Stens oil change kit. Seat and brake switch quit also!
This was also blowing fuse under the seat - installed circuit breaker/fuse
의
do you like the Gator blades?
의
댓글 달기
I have a 2006 cub cadet ztr50, my pto went out at the end of fall.  I replaced the pto switch, the electric clutch and the fuse this week and it still won’t work.  I checked all the safety switches and they appear to be working as they should.  Any ideas on how to fix this?  Thanks
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Did you ever get this issue resolved??? I’m having the exact same issue on the same model and year.
의
8/19/20. I also have pto issues on 2006 rzt50. Before I spend money, hope someone has a possible solution.
의
댓글 달기
i have a ferris is 2100 z thats about 5 years old , i've been having problems lately after about 10 minutes of mowing the engine just quits , im able to start it and it runs fine for about another 10 minutes , i've changed the spark pluges and put sea foam in the gas. now today when i engage the pto shaft with the yellow button i have to push down on the button to engage it instead of pulling up on it . id appreciate any help
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
New clutch. New Belts. New Blade engagement switch. Top of clutch turns but won't engage the blades. My deck adjuster won't rotate & mower won't go forward or reverse now even though it did work when the work was all completed.
의
댓글 달기
답변을 추가하세요
Chris 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 34
지난 30일: 161
전체 시간: 471,084
