주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
탑승형 잔디 깎는 기계. 제로 턴 반경 잔디 깎는 기계, 50인치 커팅 데크, 유압식 자동변속기.
mower deck will not lower
I have a craftsman zero turn 26hp 50 deck but my mower deck will not lower or raise when i push the switch
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 4개
선택된 해법
in the users manual on page 16 is the installation of the mower deck shown - maybe you should check those steps
if you don't have it - here is a download adress - it was the first one i've found
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
+ research
의
댓글 달기
Same thing here! Called Sears, and they sent a repair man. $99.00 for showing up. The bottom side of the PTO knob (?) electrically connects to a clutch, the wires were ripped in half!
There is a metal finger about 2" by 1/4" welded to the frame that keeps the clutch from engaging when not needed. It had broken off, allowing the clutch to free wheel, cutting the wires.
The fix: disconnect the engine, remove the clutch and reweld the finger. Or, buy a new frame ($$?), buy a new clutch, about $250, finish by putting it all together again, more $$ for labor.
I declined the estimate because I feel, by looking at the broken finger that this is a case of either poor work, or inferior material since there was no outside force, concrete, wood, etc. that could have caused this. I ran over nothing but grass. I feel Sears is totally responsible and should repair it at no cost.
We'll see how far I get.
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
Wow, thanks for the info! It sounds like this may be a common issue.
의
Same prpblem
의
댓글 달기
Drive screw got wet and will need to be sprayed with WD-40 or Penetrating oil
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I just replaced the battery when my mower wouldn't start. It still won't crank and the electric mower deck that normally raises and lowers even when the mower is turned off, will not operate. The hour meter is still running though. Any thoughts?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
william 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 27
전체 시간: 22,089
