주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
오리지널 Xbox는 Microsoft의 첫 번째로 널리 알려진 게임기입니다. 상단과 전면에 'XBOX'가 크게 새겨진 검은색 케이스로 쉽게 식별할 수 있습니다. 흔히 사용하는 도구들로 쉽게 수리할 수 있습니다.
Drive opens and closes constantly
Hi,
my original xbox drive once turned on and you press the eject button, the tray opens and then closes constantly and does not stop unless you switch off the unit.
there is no way to stop it from opening and closing.
what do you see as the issue? do I need to replace my drive?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
there are some sensors that tell the Xbox/cd drive that is need to be closed because of pressure or that it can't close. My guess is that those sensors are not working properly. For starters I would suggest opening it and cleaning the cd drive, there might be some dust or something there (and you might as well clean the rest while you're at it). If that does not work, you might have to replace the drive, which will be cheapest to buy a non-functional xbox and taking it out of it.
I don't work on xboxes so don't take my word as gospel, if anyone else has a better idea/explanation, go ahead.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
If the Xbox casing is pressing to hard on the disc drive, it will cause this problem, as it impairs the disc drive pressure sensor, make sure nothing is pressing the disc drive before closing the casing after opening your Xbox :)
의
댓글 달기
답변을 추가하세요
Anthony 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 14
지난 30일: 48
전체 시간: 11,289
