주요 콘텐츠로 건너뛰기
Released by Nokia in May 2009, the Nokia 6303 is designed mainly for voice calls, texting, and music playback.
20 질문 전체 보기
resetting security code how
My keypad is locked with security code. I changed the security code. Now I can't open it. Either I forgot what code I entered or I pressed the wrong numbers and I didn't know. Now I can't unlock my phone. What can I do to solve this?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 28
댓글 4개
Tengo un telefono que me enviaron desde inglaterra y vivo en colombia como hago para el codigo de seguridad
nokia6303 secruty code
I keep receiving phone number. 6303036998032 ? my phone ia a Samsung ?
What is going on?
unlock my moile nokia 6303i
댓글 달기
답변 2개
선택된 답변
What's your Mobile model?
Try default codes like 12345,00000.If your mobile is Nokia or Alcatel you easily reset your mobile by using Master Reset code.You can get the code from Unlock-Free.com at free of cost.Here they will generate you reset code within a minute by specifying your mobile model no and IMEI.
Note:They will provide reset codes for some basic Alcatel and Nokia mobile models only.
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
Thank you you umblocked my password Im so stupid
cant find nokia 6303ci !
Hi security code for Nokia ta-1402 8 digits
댓글 달기
Kae, follow these instructions Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
Dead link. Was going to accept it, letting you know. I also got a redirect alert from AdGuard in Chrome, now the site will not load in Safari OR Chrome. Normally I'd try and find a working reference but with 2G being doomed globally I'm just going to "solve" this one by accepting @braksa's answer.
Likely blocked by the Mac AdGuard app. Not your fault the ownership changed, but I'm letting you know.
@nick 🤣you know it does not matter as long as something worked for the OP. It’s not about accepting but about getting in solved. Best answer is always the right answer 👍
@oldturkey03 it either redirects to a dead page or very suspicious links.
댓글 달기
귀하의 답변을 추가하세요
Kae 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 73
전체 시간: 23,552
