주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2009년 5월 Nokia에서 출시한 Nokia 6303은 음성 통화, 문자 메시지 및 음악 재생을 주 용도로 설계되었습니다.
resetting security code how
My keypad is locked with security code. I changed the security code. Now I can't open it. Either I forgot what code I entered or I pressed the wrong numbers and I didn't know. Now I can't unlock my phone. What can I do to solve this?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 29
댓글 4개
Tengo un telefono que me enviaron desde inglaterra y vivo en colombia como hago para el codigo de seguridad
의 공유
nokia6303 secruty code
의 공유
I keep receiving phone number. 6303036998032 ? my phone ia a Samsung ?
What is going on?
의 공유
unlock my moile nokia 6303i
의 공유
댓글 달기
답변 3개
선택된 해법
What's your Mobile model?
Try default codes like 12345,00000.If your mobile is Nokia or Alcatel you easily reset your mobile by using Master Reset code.You can get the code from Unlock-Free.com at free of cost.Here they will generate you reset code within a minute by specifying your mobile model no and IMEI.
Note:They will provide reset codes for some basic Alcatel and Nokia mobile models only.
이 답변이 도움이 되었나요?
점수 2
댓글 3개:
Thank you you umblocked my password Im so stupid
의 공유
cant find nokia 6303ci !
의 공유
Hi security code for Nokia ta-1402 8 digits
의 공유
댓글 달기
Kae, follow these instructions Hope this helps, good luck.
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
Dead link. Was going to accept it, letting you know. I also got a redirect alert from AdGuard in Chrome, now the site will not load in Safari OR Chrome. Normally I'd try and find a working reference but with 2G being doomed globally I'm just going to "solve" this one by accepting @braksa's answer.
Likely blocked by the Mac AdGuard app. Not your fault the ownership changed, but I'm letting you know.
의 공유
@nick 🤣you know it does not matter as long as something worked for the OP. It’s not about accepting but about getting in solved. Best answer is always the right answer 👍
의 공유
@oldturkey03 it either redirects to a dead page or very suspicious links.
의 공유
댓글 달기
i forget my nokia 6303ci password ,how to open it?
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Kae 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 54
전체 시간: 25,393
