Where can I buy de-soldering wick?
I went to a hardware store and asked for desoldering wick but they had no idea what i was talking about.. any more specifics or what this actually is? thanks.
좋은 질문 입니까?
좋은 질문 입니까?
You have a couple of good options:
If you have a local RadioShack, you can find most of these. You probably don't, so check Amazon in lieu of having a local electronics store to hand. If you can afford a Hakko desoldering pump, that's what I'd recommend.
해당 답변은 도움이 되었습니까?
I like simple braided copper wire. Strip it, dip it (in flux), and wick it under heat. As the wire fills up, cut off the filled ends 1/4 to 1/2 inch at a time. Its almost free because you can use any braided wire strands you have.
해당 답변은 도움이 되었습니까?
good advice and a great way to recycle +
great idea +
Radio Shack does sell desoldering wick, but I have found it to be of low quality.
Some wick has flux in it, which helps get the solder to flow into the braid.
High quality wick can be found online at places like Markertek.com, mouser.com, digikey.com and frys.com. You may also find a local electronics or pro audio store in your area with a good selection.
해당 답변은 도움이 되었습니까?
You can order de-soldering wick online at the websites of any major distributors of electronic or soldering components. I do a lot of shopping online at Digikey and I know that they have a wide selection of de-soldering wick in different sizes. Amazon.com has also a good selection of desoldering wick.
You can remove solder by placing your wick over the solder and then heating desoldering wick with soldering iron.
More details about how to use soldering wick is here:
http://soldering-irons.com/how-to-solder...
해당 답변은 도움이 되었습니까?
Tinkersphere has desoldering wick. It's used to remove the solder off electrical connections for repairs. Get some here: http://tinkersphere.com/electronics-tool...
해당 답변은 도움이 되었습니까?
24 시간 전: 3
7일 전: 10
30일 전: 41
전체 시간: 22,456
