How to recover (internal data from) completely dead/powerless phone?
My son dunked my Evo 4G LTE under a foot of water. It was still on, so I powered it off by holding the top button down, then dried it out in rice for several days. Plugged it in, powered it on - amazing! Looked great! Had to leave for work, by the time I arrived an hour later the phone was a brick - no power, no reset holding the top button (with or without volume up or down), when connected to a computer via USB it neither registers no demonstrates any sign of power.
My main concern is the first four months of my daughter's life in video and photo stored on the phone's internal storage (android "phone memory"). I know, I should have backed it up, but I have two in diapers so best practice sometimes falls by the wayside. I did not have automatic upload set up via dropbox or google.
The phone is under warranty, sprint offered a refurbished for $35 - so I know I can get a working phone back, but I'll gladly opt to pay for a new phone and rip this one apart to get my data back.
Questions for the pros:
1. Is there any hope of recovering the data by recovering the phone? I'm not much of a hardware hacker so this would be easiest for me.
. 1a. Could it just be the battery is trashed? Is it possible to get/replace just the battery?
. 1b. Since USB doesn't bring power, could it be part of the power "subsystem," something that I could independently replace?
2. Alternatively, does anyone out there know how to get to and read this phone's internal storage?
. 2a. Is it a card or chip that can be removed and accessed outside of a phone?
. 2b. A card or chip that I could remove an put into another Evo 4g LTE, or that I could put into a replacement "motherboard" for the same phone?
. 2c. Can I solder some wires somewhere on the phone to try to access the data from another UI (this would be running in the tall grass for me, but I'll certainly try anything)?
For any solution, links to video or written narrative / instructions would be great, but even tips in the right direction or things that have worked on other phones could be helpful.
Thanks!
좋은 질문입니까?
댓글 15개
future reference dont use rice or try manually tuning off the phone, just go straight for the battery and pull it out and leave it out till it is 100% fully dry and clean.
_Z_ 의
very nice 100% fully dry and clean
Mohsin Khokher 의
The possibilities to get back your daughter images, are not finished. Contact a data recovery company, who is retrieving the image data besides repair the damaged mobile phone.
Andrew Bell 의
i just-july 13, 2016, had this happen with my LG cell phone......i took it apart, removed ththe resultsk and , wala, it works just fine, thank you. solution: the magnetic field needed resetting ...my body electro magnetic field reset the chip's electromagnetic field. try it . you could lovvvvve ner gone),.....so, i took that outta the phone, thinking i'll just swipre across these metallic little pieces to remove any moisture, did that, put it bac white plastic chip ( square but for a little piece of a coree cover , and the battery and left all to dry out. the next day, yesterday,- after charging it all night, i restarted it, but there was zilch, nada, nothing...after looking online and using what would it take to get this running again, all my data back....i thought well, maybe there's a little moisture under that
ms 의
take it apart. remove the white chip. run your bare finger over the metal plates on the back of the chip couple times. reinsert , put battery back, replace lid and retry start. worked for mine as the magnetic body needed reset, and our-your body's electromagnetic field could be plenty enuf to reset the chip's em field. mlaugh out loud simplicity.
ms 의
댓글 10개 더보기
