주요 콘텐츠로 건너뛰기
2006년 11월 북미에서 출시된 Wii는 인터넷 연결을 직접 지원하는 닌텐도 최초의 가정용 콘솔로, 온라인 게임과 Wii 숍 채널을 통해 게임 및 미디어 애플리케이션의 디지털 유통을 모두 지원했습니다.
286 질문 전체 보기
Will not turn on with red power light
I've been having issues with my Wii where the red power light is illuminated but the console will not turn on. I tried doing an AC Adapter reset and that didn't work. I checked the DC voltage and it's just over 12V like it should be. So then I followed this guide to reseat the bluetooth card but no dice. Then I read somewhere on how to do a bench test by taking one component off at a time and checking power. After resassembling the console I started over and too my behold I found that applying power after removing the optic drive made the light go from red to green. My question is, is this a safe solution to my issue? Could the red light be due to a bad optic drive?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 4
댓글 달기
답변 4개
가장 유용한 답변
vinnylastella, great way of trouble shooting. I would most certainly start by replacing the optical drive and re-evaluate from there.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Hi i think this could be more of a loose connection issue, because when you say that you have to apply pressure on the optic drive in order for the wii to work then most likely the issue is located somewhere in that area or underneath the area, so open up, check for loose connection again, and try, always triple check cheers!!
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Actually I ordered a new optic drive from Newegg.com just on a whim that that was the issue I was having. I got the new drive in yesterday and I installed it this morning. Everythings working again. I guess the bench test procedure I used worked out. Thanks for the input. I'm an electrician so I know the importance of repetative checking. >.<
댓글 달기
I wanted my power to turn on so i can play
  1. * Hit <enter> to insert another list item, and <enter> twice in a row to end the list. To get subitems, repeat the bullet character once for each level of indent you want (e.g. ##)[http://nintendo|nintendo]
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hi, I am interested in this bench test procedure. Is there a resource where I could find a step-by-step instruction?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
vinnylastella 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 9
30일 전: 39
전체 시간: 4,295
