주요 콘텐츠로 건너뛰기
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 질문 전체 보기
질문 마감됨
My chargers wont charge it
I daughter has the iPod Touch 4th generation and it wont charge on the wall charger or on my laptop.. what could be wrong with it ?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Rosie, could b a bad battery or a bad cable as well as a bad dock connector:-) Try to check the dock connector first. Make sure there are no brokenm bend or corroded pins. Clean it with some isopropyl alcohol and a few puffs of air. Pocket lint can prevent it from charging:-) If it is clean, try a different cable. If that does not help, it may be time to disassemble it and to replace the battery. Follow this guide to get it accomplished. Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 792
