replace wifi-Board on MacBook-pro retina
how to replace wifi Board on macbook-pro retina
좋은 질문 입니까?
좋은 질문 입니까?
I don't see a guide published for this yet but it's pretty easy to get to. If you refer to the 13" Retina Teardown it is shown in the 10th step.
The teardown does a bit more than you need to do in order to remove/replace the wireless card, however it does have good visuals for showing you locations of components.
To remove/replace the wireless card:
1 - Remove bottom case by removing the 10 screws
2 - Disconnect the battery (see step 6 in the teardown)
3 - Remove wireless card (see step 10 in the teardown) by disconnecting the attached antenna cables, unscrewing 1 x T5 screw and gently pulling out
Reverse for reinstallation
Hope that helps!
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 7
30일 전: 10
전체 시간: 1,941
