주요 콘텐츠로 건너뛰기
The Xbox 360 is the second game console made by Microsoft, and was released November 22, 2005.
20 질문 전체 보기
질문 마감됨
My xbox has two red rings
hey guys my xbox is flashing two red lights. a friend said it could just need a clean all the dust etc?? help
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
ashley, you should tell us which two:-) Sure, it is possible that it is overheating because of clogged air vents and/or a bad fan. I would most certainly start by cleaning it and reapplying new thermal paste to the processors. Most likely you do have the RROD and should consider to either install this RROD kit or to get the console reballed. Hope this helps, good luck.
이 답변이 도움이 되었나요?
점수 3
댓글 4개:
the two on the left ?
Top and bottom left is section 1 and 3 and indicates overheating
my friend opened it up and it was all black and horrible as it had a seriouse overheating problem, he never saw it that bad. could the reason be that the screws were applied too tight?? thanks mate
Which screws are you thinking off?
댓글 달기
It's unlikely that the overheating could be caused by any of the screws being too tight. Usually the two red lights errors are caused by the CPU overheating, the GPU overheater, or cold solder joints on the memory. In your case, it sounds like everything was overheating. Check and make sure your fans are working...if they are not, it will overheat quickly. After you verify that your fans are working, you can try re-flowing the motherboard to see if you can get it working again. Here's a good DIY on how to do that: Reflowing Xbox 360 Motherboard .
이 답변이 도움이 되었나요?
점수 0
댓글 달기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 1
전체 시간: 599
