주요 콘텐츠로 건너뛰기
A type of digital audio player (DAP), MP3 players are electronic devices that can play MP3 digital audio files.
8 질문 전체 보기
My MP3 Player is not getting detected.
Hi,
I am unable to switch-on my MP3 player and it is also not getting detected when i try connecting it to system. Please help on this.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 5개:
Information on this is difficult to find. Any make or model numbers on your device?
When i had one of these back in the day it powerd itself up when i connected it to the PC. Does yours power up ?
Did u forget and old battery in it and did battery acid leak out ?
Hi,
when I plug in my digital mp3 into computer USB port it will not detect on my PC but the digital was connected as charging.
Hi @ Jaynald Aranas
Was your mp3 player switched on?
If it was switched on, what is the make and model number of the mp3 player?
What is the make, model number and installed OS of the computer?
hi i have the same trouble but with "you have to format it before use"
댓글 달기
답변 3개
prrasuna, if it does not turn on and is not detected, I would start by replacing the battery.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
It looks like the one I have. I had alot of trouble searching fo information about it as well. I got lucky 1 day and finally found what i was looking for. Try this address ( http://www.manuals365.com/swf/element/gc... ) Hope it helps.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I have the same problem
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
prrasuna 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 11
30일 전: 11
전체 시간: 1,426
