new battery not charging
Which side of the battery is up? red wire on left or right while soldering it to the board?
Ted, CT
좋은 질문 입니까?
Ted, CT
좋은 질문 입니까?
Ted Platt, I guess we are a bit confused ;-) Anyhow, if you look head-on at your logic board, with the connectors in the northern direction (up) then the positive is to the starboard (right) side and subsequently the negative is the port (left) side. R=Red=Right :-) Amazingly enough you have white wire, it should actually be black, but it happens. check with a multimeter to see if the red and white are positive and negative polarity. Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 264
댓글 1개
where did you get the battery from?
_Z_ 의
