주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
내장된 Beats Audio™는 음악, 동영상, 게임 플레이를 위한 타협 없는 스튜디오 품질의 사운드를 제공합니다. 또한 듀얼 코어의 강력한 성능, 4인치의 선명하고 뛰어난 디스플레이, 업계 최고 수준의 카메라를 갖춘 만능 스마트폰입니다.
Cracked touch screen panel
이미지
My sister has a HTC Desire X phone.
Link: http://www.htc.com/nl/smartphones/htc-de...
It has a crack in the top screen only. The display itself is not damaged.
Can i replace the top screen. Where can i buy the parts?
Thanks in advance.
이미지
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 5개
I have HTC DEsire X phone,which top screen is damaged but display is ok,it is working.May i replace the top screen.where can i buy the parts.Thanks-Kiran
의
am using htc dsire x,my power button is totaly damagd,how to replaced the buttn....
의
Display and touch is damaged
의
My phone modle is htc desire.can I replace only a top screen glass.bcz touch with lcd display 's cost is high
의
My phone is htc desire x in which display has been cracked but touch s working.. Nd battery has a poor problem.. Can u replace battery nd display????
의
댓글 달기
답변 9개
선택된 해법
The screen can be replaced.
you can find the part on ebay:
http://www.ebay.com/itm/Touch-Screen-Dig...
cheers
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
의
댓글 달기
가장 유용한 답변
You will need an lcd separator machine to separate the lcd from the glass as they are glued together and it needs to be put on a special hot plate. Tutorial and lcd separator machine reviews can be found at www.lcdseparatormachines.com if your interested..
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
I have HTC DEsire X phone,which top screen is damaged but display is ok,it is working.May i replace the top screen.where can i buy the parts...pls hlp me..
Michael
의
댓글 달기
Be carefull! Hade the same problem with my sisters phone. I first tried to replace the Digitizer Glas, but its full glued on the LCD screen when I tried to seperate both the LCD broke. You have to replace the whole display unit. I bought them from ebay. Didn't find it on ebay.com but on the german site. It's about 90€
http://www.ebay.de/itm/Original-HTC-Desi...
Even this is the whole TOP-Unit it was still not very easy.
Hope I could help!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Hello
I´ve found it on ebay more cheaper.
http://www.ebay.es/itm/380739140385?ssPa...
I´m waiting for receive it and create a guide to all of you!
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
i needed a new glass for mine which is a htc desire 310 and found my glass on ebay it's coming form hong kong
의
댓글 달기
hi, yes be careful , Bernhard is right the digitizer glass is stuck glued with the lcd screen and it broke with me as well so i needed to change the whole display unit. i found it on ebay and it's cheap :
http://www.ebay.com.au/itm/for-HTC-Desir...
i ordered it and still waiting for it
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Had anyone got some kind of repair-guide?
I only found this video:
https://www.youtube.com/watch?v=hzRsLDah...
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Hello, I´m working on a repair guide, hope to finish it on this weekend.
의
댓글 달기
Did anyone bought some not original lcd and glass replacer?
I'm not sure if they are worth anything.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Hello, yes, I have bought 2 lcd+touch non original ( but with the HTC logo) and they works fine. The point is to glue properly the piece to the phone, because sometimes it comes out.
의
댓글 달기
how to stick the digitizer to the display\front pannel
.please help
mine is not sticking
i cleaned it with glass spray also
이 답변이 도움이 되었나요?
점수 0
댓글 달기
what you have to do is heat the screen up with a hair drier or hot blower and then remove the screen
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
[deleted] 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 17
전체 시간: 24,634
