The device doesn't recharge.
The tiny piece in the image came off, I fixed it with some superstrong glue and pressed the contact on both side down. Before try to recharge it I would like to know if there is danger, could it oxidize? and if yes, There is something that I can put on to isolate it from the air?
좋은 질문입니까?
댓글 6개
Could you place an arrow or some other marker on the piece that has come off? Difficult to determine which part you are looking at. Oh, are you talking about a torn connector of the flex cable that is now stuck in the connector on the logic board?
oldturkey03 의 공유
Added image, I don't know how it should be named but is that! :D
Giovanni 의 공유
Giovanni Riva, just to clarify. the connector came loose on the board?
oldturkey03 의 공유
yes, I re-add it with a (very) little bit of superstrong glue. Don't ask me how my brother did it! :D
Giovanni 의 공유
Trust me, things happen all the time ;-) I don't think the glue is going to get it resolved. You will have to make proper contact for it to work. Check my answer
oldturkey03 의 공유
댓글 1개 더보기
