주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus Padfone 2는 2012년 10월 16일에 발표되었으며, Asus Padfone의 후속 기기입니다.
Dust on back camera
HI, i'm a proud padfon 2 owner, but after few months of use, I notice some dust on my back camera...wow!!!It's terrible!
Can you post a guide on how to clean the back camera?How can I try to do it?thank you.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 3개
선택된 해법
Hi! Just go to step 5 in this guide, without disconnecting the battery. Asus Padfone 2 스크린 교체
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Hi! The protective camera lens just lays on top of the camera, so lay it back. Will make a guide sunday evening anyways! :)
의 공유
Im looking into a sultion using Photo-album-sticky stuff. Replacing my screen as soon as i get it, will try it then, and make a guide! :)
의 공유
댓글 달기
I have the same problem, a guide would be nice :-)
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Jonatan:
Well, I can see the Camera, but it also states that "Note that the protective camera lens will get loose!"
Right, I am not a technical genius, but how do I fasten the Protective camera lens again?
의 공유
Hi Jonatan
Do you have any good ideas how to prevent dust in the future?
Is it possible to seal it somehow?
의 공유
댓글 달기
To stop dust getting in, jam "something" in the headphone jack. I found that cutting an old headphone plug off ( the part you put in the jack ), and then inserting it in backwards ( ie rubber bit in 1st ) and then cutting the rest down to an appropriate size works well. There are apparently plugs you can buy, but I can't find any locally. I guess you could also use bluetack or chewing gum or something :P
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Defteros 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 7
전체 시간: 4,231
