주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG Splendor라고도 알려져 있으며, LG Optimus L7의 변형 모델입니다. 통신사에 따라 LG Snapshot 또는 Swift L7이라는 모델명(US730 및 LG730)으로 불리기도 합니다.
I can't find a guide to replace screen
I've been searching all over YouTube and a couple of websites but i cant seem to find a guide for the LG Venice/Splendor, I've seen similar phones that LG manufactures which have the same repair steps, would this phone file under other phones in means of repair guides?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개
Much thanks :) i really appreciate the guide and response time thanks again :D
you are welcome. Best of luck to you and thank you for accepting my answer.
댓글 달기
답변 3개
선택된 해법
alcranking, try this:"
Take apart the battery cover using notch below
이미지
Take apart the battery and remove screw (12 point)
이미지
1. Unfastening the hook, make gap between Rear Cover and Front Cover
2. Widen the gap between Rear Cover and Front Cover and hook off starting from below side (back view)
이미지
1. Take connectors & Side Key FPCB (1~9) out of the Main PCB
2. Widen the gap between Front cover and main PCB
이미지
3. Remover the Bracket Camera to upper
이미지
1. Unfastening the hook from below side, sh back side of LCD through a hole on back side of Front cover
2. Take apart Frame out of Front cover
이미지
1. Lift LCD from the frame & Take off the LCD.
2. Be careful. Do not tear the LCD FPCB
이미지
I always wonder about the grammar in service manuals :-) Hope this helps, good luck.
이 답변이 도움이 되었나요?
점수 4
댓글 4개:
So this is a screen replacement guide for the LG Venice? Please correct me if I am wrong.
Jabran, yes it is
Hey old turkey, I am grateful of the pics you put up to fix the lg Venice, but could you please make a video, because I cannot understand the pics that we'll. if you could send me the video on my email that would be great. Husban_shahid_7@hotmail.com
Sorry Husban., I did finish the repair and do not have the phone anymore.
댓글 달기
Okay I follow just didnt remove the lcd I simply replaced the outer screen now I keep getting this black smudge on my screen do I have to remove the lcd or do I use loca
이 답변이 도움이 되었나요?
점수 1
댓글 9개:
depends on "the smudge", post an image and let us see what you see.
https://dl.dropboxusercontent.com/u/5441...
Here's a link to the images and no its not water don't know what it is when I go to remove everything to remove the screen it goes away
"when I go to remove everything to remove the screen it goes away" what exactly do you mean by the? right now it looks like air trapped between the digitizer and/or LCD.
When I go to seperate the frame from the back piece to get to the screen I guess it could be air
It does look like it creates a bubble underneath,
댓글 4개 더보기
댓글 달기
Thank You :)
One more question: Do you recommend exchange by my self, or go truth an specialist. looks not complicated but I do know nothing about cellphones. looks like is just the glass screen broken but since this was broken because I press with the trunk of my car:( I do know if can be there another damage.
The other hand, I find a different options to by a screen replacement, since screen glass to digitizer and complete screen digitizer assembly? could be the last one a best option...I appreciate any tip to do it or not risk. Because I really want back my cellphone for personal reasons.
Thank You.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Replacing the LCD will not affect your memory.
댓글 달기
답변을 추가하세요
alacranking 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 16
전체 시간: 7,222
