주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2375 질문 전체 보기
iPhone 4 boots when plugged in but not when unplugged
One time my i was playing on my iphone 4 and it went black, it couldn't boot, I sent it to replace battery but when i got it, the phone said 1%, i charge it, it goes to 100%, disconnect it and it goes black and i plug it in and it says 1% again. The guy said it might be the dock connecter, please help, no phone is stressing me out, thank you.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
선택된 답변
ericksol96, the part I find very interesting is, that the person that replaced your battery, did not seem to have checked the charge function at all. If the battery is definitely new, triple check with the person that replaced it, then the next step would be the dock connector. Here is the guide for it. Again, double check with the person that you send the phone to, to find out exactly what they did. Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
There is no doubt that the battery is replaced incorrectly.
Try to correct for someone else
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
ericksol96 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 139
