주요 콘텐츠로 건너뛰기
The Sega Genesis (also known as the Mega Drive) is Sega's most successful video game console to this date.
37 질문 전체 보기
Bad, Noisy, buzzy sound
Hi!
Today I plugged my old sega genesis (I'm writing from Portugal, here we call it mega-drive), didn't use for at least 10 years. The last time I used it, it was good, I'm almost shure didn't have any problem.
Today, I plugged it and I notice the image was bad, but the worst part was the sound. I'm gonna try to describe the best I can, with my bad english, the sound was buzzy, noisy... I thought it could be a problem with the tv, or the cable, so I plugged my headphones to the genesis, and it was the same. I'm sure the problem is with the console.
I've read it could be the voltage regulator, is there any way to test them? DO you have any idea of what could be?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 5개
가장 유용한 답변
silva1983, the very first thing I'd try is to clean the game port, check on here fir a guide for that. After that check all the connections, and see if you have an RF switch, and make sure that you TV and console are on the same channel. Let us know how you connected the Genesis and what TV you are using.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I just found the solution for my same problem,
Try another original AC adapter,
I tried a same rating famicom adapter and I worked fine,
Try it,
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
You likely have the wrong ac adapter. Make sure at has an input of 120V-60Hz, and an output of DC9V-1.2A. If it doesn't, than that's your problem. If not, I would recommend that you clean the cartridge slot, and the cartridge itself.
I hope that fixes your problem.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thank you for the specifics on the adapter! Now I can double check this issue for myself as well. I have a 3rd party adaptor that can adjust voltages and polarity. I have been thinking maybe it is just going bad and I just need to increase the power that is going through the adapter to the console.
댓글 달기
The AC adapter might be wrong, make sure its for the GENESIS 1 ONLY, there are the 2 and 3, they dont work on the 1
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Well you would be doing well to put a genesis 2 adapter into a 1 as the barrel jack is a different size
댓글 달기
I am currently having the same issue as you. While I have not found my personal solution yet, I can offer a potential solution.
While everyone who has been providing answers with your AC adapter, voltages, and dirty gameports (which any of those could be correct), another issue could be your capacitors. If the capacitors in the motherboard are going bad, it could be time to replace them (as when they go bad, you can get a bad image and bad or static for sound). I intend to do this with my genesis even if it is not my solution, as a way to increase its lifespan. I would recommend you look into this solution as well. YouTube is where I learned about this.
If you find you want to do this method, just make sure you get the correct version of capacitors for your specific genesis. I have heard good things about the capacitors from Console5. Just make sure you have your soldering equipment as well!
Best of Luck!
  • Jakes Restorations
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
silva1983 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 5
7일 전: 16
30일 전: 83
전체 시간: 14,543
