주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sylvania의 4GB 3.6" 터치 스크린 비디오 MP3 플레이어입니다.
Why won't player turn on?
I have tried over and over again to turn my player on. I have tried charging it several times and have even tried the reset button, but it will not come on. It was working fine, then I started downloading some more music when it shut off and would not turn back on. My laptop recognizes that it is pluged up. I only have a USB cable to charge it and I have even tried three different USB ports on my laptop. What is the cause and fix for this problem?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 3개
선택된 해법
henryr79, it does sound like a battery failure. If it has discharged to below its threshold it will no longer accept a charge or hold a charge. I would start with that. Follow this teardown to change your battery and re-evaluate. hope this helps, good luck.
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
What does a battery cost and where can one be bought?
의
Once you have it apart, there should be a number on the battery. Use that to do a search according to your location.
의
댓글 달기
It was not working and how to fix it.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Um... what are you talking about???
의
댓글 달기
My sony walkman wont turn on
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
henryr79 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 20
전체 시간: 3,026
