주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2010년 4월 출시 / 2.4, 2.53 GHz Core i5 또는 2.66 GHz Core i7 프로세서
MacBook Pro is just dead
My Macbook Pro does not start (boot) anymore, no sign of life at all.
What I tried so far:
1. pressing the power on button in various combinations with the cmd, ctrl and shift buttons (as suggested on some websites)
2. removed the battery, pressed the start button for at least 10 seconds and replaced the battery
3. removed the battery and tried to start without battery (but with the battery charger connected)
Doing a battery check (pushbutton at the left side) rusults is no leds lighting when the battery charger is disconnected and all leds lighting when the battery charger is connected.
Any help is appreciated,
Rik
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 2개
A history of the machine might help.
의
the macbook worked fine for years, some days ago I left it in working order, when I returned one hour later it was dead.
의
댓글 달기
답변 3개
선택된 해법
Knowing the exact year/model would assist us with getting specific info for you.
Check the power adapter voltage with a meter. Perhaps it has failed.
Can you borrow another adapter or charge the battery in another MacBook ?
이 답변이 도움이 되었나요?
점수 4
댓글 25개:
I tried another adaptor without any result.
The model is A1286, year 2010.
의
Rik. Thanks for accepting my answer but its a little premature if you are not up and running. Now I have the model no ill see if I can't give you more specific advice. Are you willing to put your Mac apart to investigate?
의
Ok, I "unaccepted" the answer.
As long as it can be reversed I am willing to disassemble the Macbook.
Thanks, Rik
의
do you have a multi meter or can you borrow one?
의
yes, I have a multimeter
의
댓글 20개 더보기
댓글 달기
Did your MagSafe only light up with a dim green light?
Mine shows only a dim green light with the battery in or just the AC. The battery lights are all off. Do you think your fix would work in my case?
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
I had no LEDs lighting when running only on battery and all LEDs lighting when running on the AC power supply.
But if you have the screwdrivers, the resistor and a voltmeter at hand it takes less than half an hour to try it.
의
댓글 달기
Anyone else in this situation can try this, to verify if the battery is the culprit (on older Mac models with removable battery):
https://osxdaily.com/2019/06/14/how-boot...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Rik 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 34
전체 시간: 4,115
