주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
무료 수리 안내서, 고품질 교체 부품 및 도구로 iPhone을 직접 수리하는 데 필요한 모든 것을 제공합니다! 최신 아이폰 16 라인업부터 2007년에 출시된 오리지널 아이폰 2G까지 iFixit은 모든 아이폰에 대한 무료 수리 안내서와 분해 정보를 제공합니다.
Hardware diagnostics service software
Hello,
I started a little bit trading with iPhones. Is there any way how can I make hardware check - diagnostics of problems by some software?
And what repair services use when they provide "diagnostics" service.
Thank you
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 16
댓글 3개
my iphone 6 shut off just like that and now it only comes on when i plug the cable in, but this the logo come on and then cuts off. i started it up in dfu mode and restored it but its just saying error 4005. what should i do?
My iPhone 6 Plus has problems, I try and touch the screen sometimes and it doesn’t work, and when I try to download something it shuts off the iPhone and restarts it and all the other iPhones dont have these problems, my iPhone has many more problems to
@Robin Mason This topic is not what you want to ask.
댓글 달기
답변 4개
선택된 해법
radesek, here is my answer to a very similar question:" You could check on here and see if that will help you a bit. "It’s called the iPhone Configuration Utility, which allows you to examine logs from your iPhone or iPod Touch, to apply configuration and provisioning profiles, and more. The tool is very interesting!" from here I believe the software you are thinking of is called "Behavior Scan" More info about it on here and here. I would also like to recommend the iPhone Troubleshooting Guide compiled by one of the users on here. Hope this helps, good luck.
이 답변이 도움이 되었나요?
점수 2
댓글 6개:
Thank you, but I already read this information. The problem is, that I think iPhone Configuration Utility is not exactly what I am looking for and that Behavior Scan somehow cant be accesed without login of Apple employee right?
I need software that will test hardware things like working wifi, camera, jack and stuff like this. Is it possible?
Can be this a sollution? Problem is I can not be sure with it, since my iphone does not have panicplist entry.
I do not think that there is any diagnostic software that is available for an end user, that will tell you exactly what is wrong with the iPhone. That would be to easy;-) From what I've read if your phone shows panic.plist. then you may have a hardware error, not very descriptive.
Where to look for that panic.plist file?
is there any point having a website with all dead links
댓글 1개 더보기
댓글 달기
Phone doctor plus in the app store, however contact the developer for business solution.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I'm using Battery Health - Your Battery Doctor app in the app store, very nice app
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Hello, my company uses NSYS tools. It’s quite easy to use and accessible.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
radesek 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 11
지난 30일: 34
전체 시간: 117,776
