주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Linksys WRT54G(및 파생 모델인 WRT54GS, WRT54GL, WRTSL54GS)는 Linksys에서 출시한 Wi-Fi 지원 주거용 게이트웨이입니다.
problem with router connection
Dear Sirs,
I have the following problem with Linksys router wtr54gl: after an unsuccessful attempt to install new software, I have no communication with the Internet and can not reset the router to factory settings.
Expect some advice.
Credit: O. Boev
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Oghi Boev, when you say "attempt to install new software" are you referring to installing new firmware for your router? How did it fail? How did you try to do it?
의 공유
댓글 달기
답변 3개
선택된 해법
You must connect to the router via Ethernet cable for setup/upgrade. If you pooched the upgrade buy a new router... software fixes/hacks are not really our thing here.
If this Answer is helpful please remember to return and mark it Accepted.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
해당 답변은 원래 다른 질문에 답변 된 것입니다.
Here's the Linksys support page for your unit WRT54GL Wireless-G Router It has all you should need to answer your questions.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Try by resetting your router and re-configure it again. Please note that your all saved setting shall gone once you have done hard reset so i would suggest if your using ADSL then get your PPPoE account setting from your ISP first and then do this.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Oghi Boev 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 9
지난 7일: 16
지난 30일: 25
전체 시간: 841
