주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Epson Stylus NX415는 컬러 잉크젯 프린터입니다. 이 프린터는 가시적인 메인 칩 뒤에 수분 센서가 있는 T088/69/68 잉크 카트리지를 사용합니다.
How do I bypass this general error?
I was just gifted an Epson Stylus NX415 hoping to use it at least as a scanner but when I power it on I get this error on the LCD display:
Error:
A printer error has occurred. Turn off the printer, then press On button to turn on. See your documentation.
I've checked the user guide and can't even find this status message listed in the documentation. When I try to power cycle the printer I get the same error. I've tried booting it with and without paper loaded.
When I have the OSX System Preferences panel open it lists the printer as on but idle:
이미지
And within the printer utility I get "General error," which is likely one of the least helpful error ever. Ha!
이미지
Is it a firmware issue? If so, does anyone know how to reset the printer to factory settings?
Cheers!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 3개
선택된 해법
If you already have turn off and turn on the printer and error doesn't clear up, try turning it off and check for any obstructions that may be blocking the inks from moving then turn it on. If the issue persists, your printer already has a hardware issue particularly the printer part of your product. I suggest that you contact Epson for a replacement printer if it is within the 1-year warranty period from the date of purchase. Or Check Out This Link For More Help http://www.fixya.com/support/t11620251-e...
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Thanks Harvir! It looks like it is a hardware issue. I'll call Epson on Monday. Cheers!
댓글 달기
It may happen after a load of ink clogs your paper sensor.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
i have problem with Machin epson l800
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Tod Robbins 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 19
전체 시간: 9,020
